| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Well, this idea of mine isn't actually for a true atomic clocke per-se.
However, the idea is to use a microwave signal generator and to decade it down to milliseconds, seconds, minutes, hours, days, weeks, months, and years. I think that by decading a high accuracy source of around 4Ghz, I should get a very accurate second timer output. The frequency standard I have in mind is an HP8616A signal generator. It is a cavity tuned industrial signal generator and I believe it will stay on a given frequency for a long time. Does anybody have any ideas or comments about this idea? Any circuitry ideas?
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#2 |
"I believe it will stay on a given frequency for a long time."
Well, if that's all you know, how do you know it will be more accurate than, say, a $9,95 Japanese watch? Look upo the accuracy of the signal generator, it will probably be given in ppm (parts per million) where 1000 ppm = 0.1%. Then check up long term stability. For ultimate requirements you can't do better then a radio-controlled/synchronised clock; these are in effect atomic-controlled. However, if you want to have fun, go ahead and build your design. Jan Didden |
#3 |
Well, actually, my idea is after that of the clocks used by the NIST in colorado for the WWV UTC broadcast system.
I simply want to see if I can make a fairly accurate clock from this nice old sig gen I have sitting around, simply for something to do with it. I haven't yet designed anything. I am just thinking up ideas right now and I believe it would be a very good project to attempt.
#4 |
Here in Australia at least, many of the TV stations have their horizontal sync frequency (15,625Hz here) derived from a rubidium frequency standard, accurate to 2 parts in 10^11.
Dangle a wire across the back of the TV, have a little tuned cct to get this frequency, multiply it by x64 with a 4046 phase locked loop for 1.00000000000 Mhz, (more or less) Edit: Info was from a mid 70's Electronics Australia magazine, but probably still true enough. |
#5 |
#6 |
Circlotron: Very interesting idea, I like that idea. Still, I want to see what I can do with this signal gen.
Rob M: I already have that.
#7 |
#8 |
OEM GPS receiver boards provide a 1ms and 1s "tick" signal used in applications to update the screen synchronically to the UTC second.
Very accurate. |
#9 |
there is an EBay T&M for Calibration and Standards and rubidium oscillators, complete HP clocks go for $40 to $200.
for me, I just keep my HP3586C "Measurement Receiver" running all the time -- it has an ovenized oscillator and I can "beat it" to any receivable standard. I use the 10MHz clock to drive my HP5334B counter and HP3336B generator. |
#10 |
How about a microcontroller that can interface to tcp/ip protocol, wifi standard? you can receive it via a computer network via Network Time Protocol? Surely Maxim IC make something capable of this.
| Eltax Atomic 8.2 problem, help! | DorinD | Subwoofers | 1 | 9th January 2009 02:13 PM |
| ATOMIC 5000 D Repair urgent please | basswarriors | Car Audio | 3 | 6th May 2008 11:42 PM |
| Improve CD playback with an Atomic Clock! | rcavictim | Swap Meet | 0 | 29th January 2006 05:55 PM |
| Atomic bombs and decibels. | Circlotron | Everything Else | 33 | 2nd February 2004 08:02 PM |
| Page generated in 0.12004 seconds (72.27% PHP - 27.73% MySQL) with 11 queries |
