Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Philips SPA7350 (2.1) potenciometer
Old 28th July 2012, 05:52 PM   #1
Sreten80 is offline Sreten80
Default Philips SPA7350 (2.1) potenciometer
Is it possible to use this 2.1 system without remote control?If not, how to bypass remote and use speakers without?What is my option to use speakers without remote?Does any have pinout for mini 9-din for volume control?IC is TDA7379. Thank you!
Old 31st July 2012, 09:59 PM   #2
Help, please!
Old 1st August 2012, 02:04 PM   #3
PlasticIsGood is offline PlasticIsGood  United Kingdom
PlasticIsGood's Avatar
Do you not have the rc receiver unit? It also includes the manual volume control, a second input, and headphone output.
It's not clear where the volume control chip is. If it is in the main unit, find it and then find its datasheet. It should be possible to simply connect signal inputs to outputs. More ambitiously, you may be able to trace control inputs to the mini din, and connect a suitable rotary encoder.
Alternatively, find the datasheet for the TDA7379 and connect the audio input jacks to the amp via whatever caps and resistors it specifies. Those should be on the board, so with some circuit tracing you should be able to use what's there.
Old 1st August 2012, 02:55 PM   #4
No, it is wired volume control.Tnx for replay but i need little simple solution like, where to put what, couse i am begginer at electronic
Old 1st August 2012, 04:03 PM   #5
That's not going to happen, but good luck anyway.
Philips SPA7350 (2.1) potenciometerHide this!Advertise here!
Philips CDM4/36 (new) and Philips CDM3 DAC2011 DIY HiFi Supply 7 7th April 2013 09:43 PM
Philips CD 721 or Philips CD 710 info5 Digital Source 3 19th July 2012 09:15 AM
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
