Possible Stereo set up Room Change, Impact on sound.... ?? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th July 2012, 01:54 PM   #1
Default Possible Stereo set up Room Change, Impact on sound.... ??
Hiya,
Just trying to get a rough idea as to the difference a room change may have on a stereo set up.
Currently, in a 3.5 x 3.5m room, painted plastered walls, laminated floor with rug, wooden blinds, not alot of furniture so set up cushions in various places when sitting listening to cut down on high frequency reflections. After tweeking this and that I'm at a point were the sound is rather nice and clear, maybe a bit on the thin side but will work on that.
The two bass ports on each floor stander are plugged to stop bass flabbyness, yet still goes quite deep :-)
The new room I'm hoping for may be 4m x 8m, carpet and glossy wall paper, probably still not a lot of furniture.
I'm guessing the highs may dampen a bit with all that carpet, and curtians rather than blinds, and may have to unplug a bass port or two... to get a bit more movement from the drivers to fill the space.. ??
Any one got any other thoughts?
Many Thanks,
Cheers
DC
Old 15th July 2012, 05:25 PM   #2
Speakerholic
Cal Weldon's Avatar
Tough to give an idea what it will sound like, best just to try the new room and see what you think. Once that's done come back and maybe we can help iron out things you are not happy with.
planet10 needs your help:
Let's help Ruth and Dave
Old 15th July 2012, 05:53 PM   #3
fair enough, fingers crossed I will be back :-)
Old 23rd July 2012, 08:51 PM   #4
When I moved I was kind of lost with too many parameters. I found it quite helpful to play with a software called CARA. Computer aided room analysis. Not too expensive and easy to use. It is a simulator: you can learn a lot, but it will not make listening tests redundant. So the fun stays!
radical change to a set of kit boxes busterno1 Multi-Way 20 17th June 2010 02:32 PM
perfect room for stereo? heinz1964 Everything Else 7 28th August 2008 06:41 PM
Can the ON/OFF switch impact sound? Dominick22 Chip Amps 100 29th May 2006 11:09 PM
Modded Sonic Impact vs my SET monoblocks gilbodavid Class D 10 14th November 2005 06:08 PM
Room set up Guss Multi-Way 1 20th July 2003 11:35 AM
Copyright 1999-2017 diyAudio
