Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Problem with CMOY Headphone Amp
Old 1st June 2012, 02:17 AM   #1
graemedb is offline graemedb
Default Problem with CMOY Headphone Amp
Hey Im super new to circuitry, this is actually my first soldering attempt. There is sound going through my headphone amplifier but no boost in volume at all. I bought the single hole perf board cause i couldnt find the radioshack board they are using in the tutorial. Can anybody help me get this thing boostin levels? Sorry the picture of the soldering is pretty blurry.
This is the layout I am following http://tangentsoft.net/audio/cmoy-tu...ayout-0150.pdf
This is the schematic (don't quite know how to read em yet) http://tangentsoft.net/audio/cmoy-tu...angent-sch.pdf
and this is the tutorial Assembling the Amplifier
Thanks a bunch, I really wanna get this thing goin!!
Old 1st June 2012, 02:36 AM   #2
Alvis is offline Alvis
Banned
These are great projects.
I notice you have a volume pot, do you really need that?
Try it without the volume pot and double check your resistor values.
Old 1st June 2012, 03:36 AM   #3
ChicagoJTW is offline ChicagoJTW
Do you have a multimeter? If so, you can start by checking the power in. Put your positive probe on the V+ (pin 8--upper right) and the negative probe to ground. Then take a reading with the positive probe on the V- (pin 4--lower left). With only one battery, you should show approximately +4.5V and -4.5V coming into the op amp. If the power is good, then you can start troubleshooting the signal.
Old 1st June 2012, 03:41 AM   #4
Took out the volume pot and its still the same, checked all the resistors and they seem to be fine. Signal is going 4.41 in pin-4 and 4.41 thru + side of battery
Old 1st June 2012, 06:05 AM   #5
Okay, that's good. Now you can try to figure out what's wrong with the signal. If you're using a computer or iPod as a source you can download a test tone to check your signal voltage. (Get a steady tone; don't use a sweep.) Play the test tone recording through your CMOY with the multimeter clipped to the each of the input leads. You've got two signal wires and one common ground soldered to the 1/8-inch jack. Measure the AC voltage on each channel (left is the tip, right is the sleeve), and write them down. Don't change the volume settings.
Now clip your multimeter negative lead to ground and clip or hold the positive probe on pin 1 (upper left). Write down the output voltage. Repeat the process for pin 7 (second from the top on the right). Write down the second output voltage. Now compare the input and the output. You should be getting gain of about 11X on each channel.
Old 1st June 2012, 12:04 PM   #6
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
I can't tell 100% from the picture,but it looks like you have solder bridging across the op-amp input +/- and output pins? (along the outer left and right sides of the board,in the third picture.) If that's the case,then you won't have any gain,and might even lose some.
You'll need to double check the connections,and clean up any solder bridges,etc.
Old 2nd June 2012, 09:30 AM   #7
Did a quick rebuild of the whole thing using a similar board to the one in the tutorial and its all workin now!! Sounds great! A lil bit of a hiss, so i might put a resistor into R5.
Thansk so much for the help..now to learn guitar pedals
Old 2nd June 2012, 11:19 AM   #8
Banned
Cool, pretty exciting eh?
I like how the little cMoy brings out the bass and detail, even at the same listening levels as before.
Problem with CMOY Headphone AmpHide this!Advertise here!
4 channel headphone amp based on Cmoy tomcc Headphone Systems 9 24th May 2011 01:55 AM
Cmoy headphone amp? littlerick Headphone Systems 28 22nd February 2010 05:41 PM
Cmoy Headphone amp Puffin Headphone Systems 12 23rd May 2009 06:30 PM
Cmoy headphone amp sammydee Headphone Systems 2 21st May 2009 12:47 AM
CMoy Headphone Amp ... I'm Back! lgreen Headphone Systems 4 23rd January 2009 05:37 PM
Copyright ©1999-2017 diyAudio
