Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 10th October 2003, 04:29 AM   #1
chris ma's Avatar
Unhappy Fried a slow blow 4 A fuse
During unit testing my CLC power supply, I somehow managed to reverse polarity of one bank of 10@4700uf caps located right after a 4 diodes bridge before the air coil inductor. What other parts might have been damaged by this? The PSU was tested with no amp connected at the time. I have even told myself not to work on it when I am tired!
The layout is;
400VA 22-0-22 Transformer---->Bridge--->C---->L-----C
Also I was using a thick copper bar as the power bus and my 40Watt solder iron did not work with it at all, so I used a bustane gas blow torch to do the soldering, you don't want to see what the PSU looks like now. I really skinned the caps not by intention though. The insulation of the hook up wires were on fire and they are all charred now. I hoped the caps survived the fire...
Chris
The Butcher
Old 10th October 2003, 05:40 AM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Lesson learned ?
Old 10th October 2003, 06:59 AM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Re: Fried a slow blow 4 A fuse
Chris
The Butcher
I particularly like that Butcher-regard
Now is the right time to buy a digicam and post some pictures.
To go on with your 4A SlowBlow, check your bridges.
If these are OK, nothing else will be harmed IMO.
The fuse probably reacted quickly enough not giving the time to the
transformer or caps to be damaged.
/Hugo
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 06:11 PM
New ST-70 blowing 3 amp slow blow fuse Jimthemeek Tubes / Valves 22 3rd May 2009 10:56 PM
Sa-5.1 blow fuse jpweaner2 Tubes / Valves 0 3rd May 2007 01:36 PM
Soundstream SA 245 - Blow Fuse babygot Car Audio 4 7th January 2005 05:06 PM
fast / slow blow fuses millwood Everything Else 3 5th January 2004 05:49 PM
Page generated in 0.05834 seconds (82.02% PHP - 17.98% MySQL) with 10 queries
