Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
3 dB
3 dB
Old 24th May 2012, 03:28 PM   #1
doctordata is offline doctordata  Australia
doctordata's Avatar
Default 3 dB
Like to start this thread to take away a lot of misassumptions about Voltages , Watts and the coupling of those lovely things to our human ears .
I read this forum almost daily and I’m still surprised ( but understanding ) members asking questions , that would be all “answered” under our human ear “3dB” rule .
I can explain this Logarithmic stuff , but there must be a teacher out here on this forum that will do much better than me ! so come one , please explain the 10log and 20log stuff !
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 25th May 2012, 11:54 AM   #2
DF96 is offline DF96  England
I'm not sure what you mean by the human ear "3dB rule".
Decibels are a way of describing ratios. Because adding and subtracting are easier for humans to do than multiplying and dividing, we make use of the properties of logarithms (which are the inverse of exponentials). The maths is taught in a high school near you.
The Bel is simply the base-10 log of a ratio. It was found to be inconveniently high a measure, so instead we use a tenth of a Bel - a decibel. To get a ratio in dB you take the log and multiply by 10.
In electronics we are mainly interested in power ratios, so take the base-10 log of the power ratio and multiply by 10. The result is the power ratio expressed in dB.
Power goes like voltage squared. To square a number you double its log, so to get a power ratio in dB from a voltage ratio (e.g. a voltage gain) you take the base-10 log of the voltage ratio and multiply by 20. This is only strictly correct if the same impedance is used, but there is a convention in electronics that when we are only interested in voltage gain we use dB anyway and ignore the impedance difference.
So 6dB could mean a strict power ratio of 4, or it could mean a voltage ratio of 2. The context should make it clear which is meant. In the case of equal impedance the two ideas are the same.
I don't know if this deals with your question, but it is an area where people seem to get confused and sometimes confidently assert wrong ideas which they have picked up.
Old 25th May 2012, 11:58 AM   #3
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I had a column in one of the previous diyaudio newsletters explaining all this in somewhat more detail.
In case you missed it, it should still be on teh forum.
Not sure what the '3dB ear rule' is - never heard of it.
-3dB of course simply being the point where the voltage level has decreased by 3dB to 0.707 times the starting value. Is that what you mean?
jan didden
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 25th May 2012, 12:02 PM   #4
hitsware is offline hitsware
I think the ' rule ' is that 3db is the minimum audible
change in level.
Old 25th May 2012, 01:47 PM   #5
jan.didden's Avatar
That's not correct. There are documented tests that fractional dB differences are audible.
What may be meant is that 3dB difference is perceived as doubling of sound level (not sure it actually is though). Probably need to look up on the Fletcher-Munson or similar graph.
jan
Old 25th May 2012, 02:01 PM   #6
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
3 dB
10dB is percieved as doubling of sound level.
3dB being the most commonly noticeable change is something I have heard said before. It's kind of a good step.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 25th May 2012, 03:08 PM   #7
3dB is half power, but I'm not sure what that has to do with ears.
Old 25th May 2012, 03:27 PM   #8
StigErik is offline StigErik  Norway
StigErik's Avatar
Phon curves are a better way to describe perceived sound level. 10 phon is a doubling, meaning from 10 to 20 there is a doubling, and from 70 to 80 ... and so on.
As it happens, 10 phon is 10 db @ 1 kHz. But not necessarily 10 dB at other frequencies....
Equal-loudness contour - Wikipedia, the free encyclopedia
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 25th May 2012, 10:02 PM   #9
jan
That's not correct
3db is 'measureable' as doubling of level,
but is the (commonly) least perceptable
change. Hence the logarithmic scale used.
Old 25th May 2012, 10:07 PM   #10
StigErik's Avatar
Wrong. Its easy to hear much smaller changes in level than 3 dB.
3 dBHide this!Advertise here!
Two versions of Fane's Full Range Model "Studio 5M" - 100 db and 92,5 db ?? tiefbassuebertr Full Range 10 8th December 2015 01:41 PM
Audax PR170M0 –100 dB or just *94 dB?? rick57 Multi-Way 44 22nd December 2013 01:50 AM
Why 3 dB? gmphadte Solid State 6 20th September 2011 11:10 AM
116 db peak db how loud is that 8cube Multi-Way 21 8th November 2007 07:45 AM
Coverting dB/2.83w to dB/1w moving_electron Multi-Way 27 9th March 2004 03:47 PM
