Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 21st May 2012, 06:19 PM   #11
godfrey is offline godfrey  South Africa
Originally Posted by DF96 View Post
Resistors use a lot of silicon?
Possibly, but it's hard to imagine that chip real estate is such a big issue. Perhaps there's some difficulty in creating decent quality or close tolerance resistors. I notice that specifications that rely on resistors tend to be quite badly defined (e.g. quiescent current or max output current).
Better to use three or four matched BJTs than a resistor.
That does seem to be the approach sometimes taken, but I'm still wondering why.
Old 21st May 2012, 06:22 PM   #12
SY's Avatar
Close tolerance is hard but close matching is easy. Of course, the resistors also degrade noise specs since their Johnson noise is uncorrelated.
edit: I see that one of the smart guys has already mentioned the noise issue.
If there's a sucker born every minute, where do the rest of them come from?
Old 22nd May 2012, 07:52 AM   #13
Thanks, SY - That's good to know.
So for an opamp circuit like the one below, we don't know exactly what the idling currents of the two input stages are, but they will be closely matched (when the common mode input voltage is close to zero).
The main feature of the circuit is that the common mode input voltage range extends about 0.5V beyond the supply voltage in both directions.
The benefit of biasing the input stages with resistors is that as the common mode input voltage moves from rail to rail, control is handed over gradually from one input stage to the other, with the total transconductance remaining constant.
I'd been wondering how guilty to feel about the resistors, but it should be fine.
New preamplifier kits with JFET or BJT input stage PMA Vendor's Bazaar 10 11th September 2011 12:38 AM
MC preamp input stage (BJT based) questions jason12 Analogue Source 5 5th May 2010 05:12 PM
Monlithic transistor IC for input stage design? Bitrex Solid State 16 24th June 2009 01:23 AM
Input stage biasing - BJT steve_mak Solid State 24 11th July 2007 03:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
