Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
How can I stop crackling noise from speakers?
Old 5th May 2012, 03:27 AM   #1
zBernie is offline zBernie  United States
Default How can I stop crackling noise from speakers?
I have a pair of Behringer MS20's speakers connected to an Apple TV via an optical cable. When I power on the speakers, and start to play music, there's a loud crackling sound, and I cannot hear the music. I then pause the music, then hit the play button again (on my iPhone or iPad), and the music plays fine. This is reproducable every time I power on the speakers. I have a similar setup in another room except they speakers are Behringer MS40's. I tried swapping the optical cable, the shielded speaker cable, the speakers themselves, and with the MS40's connected, the crackling occurs. I then tried plugging the speakers into a different outlet, and no crackling.
I'm almost certain the problem is with the outlet, which my TV and other equipment are also plugged into as well. Can anyone recommend how I might mitigate this crackling noise? Is there some type of line filter I could use?
-Thanks
Old 5th May 2012, 04:07 AM   #2
Inductor is offline Inductor  Portugal
Inductor's Avatar
Try disconnecting the TV antenna first and see if sound is better. Also your country/flag my help with the new connections, for pro-members technicians/engineers.
I had a similar problem with a KEF subwoofer (active) that was making a zummm sound, easy solution, I stopped using subs. My problem (had no antennas) I think that was with the different ground connections from different Amp-sets and maybe not using shielded cable, also from the mains (caps?) Surge Suppressors/Protectors, this in my case.
Old 5th May 2012, 04:59 AM   #3
wwenze is offline wwenze  Singapore
Your symptoms sound like the speakers are unable to lock the signal properly on the first try, but you say a different power socket solves it, hmm...
Maybe the SPDIF connection is borderline useable, and extra noise from the AC killed it. Try a lower sampling rate/bit-depth? Or perhaps another source.
How can I stop crackling noise from speakers?Hide this!Advertise here!
crackling noise in crown amp ampcabinets Solid State 4 25th April 2011 10:35 AM
Crackling noise in left channel. fritz39 Solid State 1 21st January 2009 12:57 AM
Help! New Yaoin MC-100B with intermittent crackling noise from speakers dynaudio_tube Tubes / Valves 1 1st July 2008 02:40 PM
Help with crackling noise Free0 Digital Source 0 15th June 2004 02:37 AM
Crackling/static noise from CD63ki SimontY Digital Source 5 3rd August 2003 10:23 PM
Copyright ©1999-2017 diyAudio
