Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Hiding cables
Hiding cables
Old 1st May 2012, 07:31 PM   #1
davecooper is offline davecooper  United Kingdom
Default Hiding cables
I'm interested how people hide speaker cables. We are carrying out some major work in a room and the aspiration is that there will be no home entertainment gear or cabling showing at all. However, the speaker cables are a problem. The position of the audio gear and the speakers is pretty much fixed but are not in ideal positions from the point of view of hiding cables. The only solution I can see at the moment is to run them under what will be a wooden floor. I had also considered running them behind the skirting but was not sure about the sharp bends at the corners. At the moment, the room is bare block which will eventually be plastered and the floor is solid concrete. Any advice would be welcome.
Old 1st May 2012, 07:36 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Hiding cables
If you don't mind them being in the room you can use something like this.
Corner Duct Raceways – Disguise Cable Runs as Crown Molding
planet10 needs your help:
Let's help Ruth and Dave
Old 1st May 2012, 08:17 PM   #3
Thanks Cal. It's another consideration.
Old 1st May 2012, 09:58 PM   #4
DF96 is offline DF96  England
Sharp bends are OK for speaker cables, provided that the copper does not slowly cut through the insulation and eventually short out. It is RF cables that should not be bent too tightly because this creates extra reflections.
Old 1st May 2012, 11:04 PM   #5
Enzo is offline Enzo  United States
Vaguely related:
I work in pro audio, and that includes sound systems for churches. Talk about the original committee system! Someone "designs" the system, someon else makes the purchase. The electrical guys set it up and wire it, and finally the carpentry volunteers hide the cables.
Inevitably a certain percentage of them will come in with amplifier problems, and come to find out that the carpenters, knowing nothing of wires, put up molding to covr the cable run, and drive nails right through the wires, sshorting the circuit.
Having told that story, if care is used, molding would be a simple way to conceal wires.
Like DF96 said, tight corners are only a concern for RF, where it becomes an inductance.
Old 1st May 2012, 11:57 PM   #6
rob g is offline rob g
You could always use some kind of skirting trunking.
An example:
Skirting Trunking
Others make their own false skirting to hide cables.
Orac skirting looks tidy:
http://www.house-martin.com/int_skirting.php
Old 2nd May 2012, 08:27 AM   #7
The Orac skirting looks less "industrial" than the RMS stuff. Will look at this further as I am currently deciding on what skirting to fit anyway. Has anyone any experience of flat cables designed to run under carpets etc.
Hiding cablesHide this!Advertise here!
Old power cables make good audio cables? paean Parts 9 2nd November 2010 08:21 AM
Where are nippon transistors hiding ? MaxS Parts 5 9th June 2007 07:39 PM
ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! ssabripo Everything Else 3 26th October 2006 02:33 PM
Hiding woofer enclosure in attic? mjgraves Multi-Way 4 5th July 2005 03:12 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
