Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 24th April 2012, 09:34 PM   #11
I've been fiddling with my amp recently to reduce hum, and found that one of the contributing factors to my earthing problems was the preamp, so it's good to try and rule it out.
Old 24th April 2012, 10:41 PM   #12
redjr is offline redjr  United States
its my new little preamp that was creating some hum - that I at least reduced. Further testing as I described above seemed to indicate otherwise. At this point I'm not sure where its entering the audio chain.
Old 27th April 2012, 12:39 AM   #13
Update....
After more 'process of elimination' testing I discovered that the hum I was getting was indeed coming from my new amp build. I had tried hooking up some shielded cable from the RCA inputs to the amp module, but decided not to ground the shield. The decision not to use the shield (2nd wire) was based on some other discussions I had read here about star grounding strategy. For some reason it did not work for me.
To fix the problem I decided to use - readily available - 2 twisted pairs from some CAT5 cable I had. This was a departure for me from using RG-174/U coaxial cable. Connecting up both wires, at both ends, signal and ground has virtually eliminated the remaining hum. While there was some hum issues with my source selector device(since fixed), it was further amplified in my amp. Problem solved. It's now time to get the amp off the bench and into service.
Ground loop isolation to get rid of hum? Peter Pan Music 24 22nd May 2011 10:29 AM
Intercomponent ground loop hum pforeman Tubes / Valves 15 4th November 2009 02:24 PM
Ground loop/hum on Inca Designs ID1P/ID75 quickie Solid State 39 13th September 2008 06:31 AM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
Ground loop hum jag Pass Labs 20 25th November 2002 05:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
