Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 23rd April 2012, 02:57 PM   #1
Default light beam switch needed
I need a circuit to allow a relay to be activated and power a small geared down motor when a photo transistor sees the light from a IR LED and to deactivate the relay when the beam isn't seen. I am passing an object of roughly .450 in diameter inside a 1/2 ID pipe. When the pipe is full I need the motor to stop.
Any ideas?
Old 23rd April 2012, 03:10 PM   #2
KatieandDad's Avatar
The problem with such a design is ambient light and false triggering.
Simplest way to ensure no false triggering is to use an NE555 (for example) to generate a known frequency and then just use its PLL counterpart (I can't remember it off the top of my head by I seem to recall the NE564) to detect it.
http://noel.feld.cvut.cz/hw/philips/acrobat/1057.pdf
Old 23rd April 2012, 03:14 PM   #3
It would be a black tube so light shouldn't be a problem.
Old 23rd April 2012, 04:11 PM   #4
In which case its pretty simple.
You simply need to wire up the IR LED exactly as you would any other LED with a series resistor.
The sensor is an IR transistor (assuming its NPN) with its Base OPEN CIRCUIT (Normally - they do differ), Emitter to 0V and its Collector to the -ve of the motor. The +ve of the motor is connected to VCc.
Might be better to switch the motor with a relay to reduce the current through the IR transistor.
Old 23rd April 2012, 06:54 PM   #5
will this work?
Old 24th April 2012, 06:17 AM   #6
Use 555 as schmitt trigger.
Gajanan Phadte
Old 24th April 2012, 11:25 AM   #7
I don't want a schmitt trigger.
power on switch, no light! gychang Parts 13 7th May 2011 01:34 AM
LM3886 noise when turn on the light switch linhoffan Chip Amps 14 6th May 2011 03:37 AM
Dir1701 Muting when switch on/off light azyx Digital Source 4 13th April 2004 11:59 AM
Copyright ©1999-2013 diyAudio
