| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hey, not to sure where to post this as I'm new to this site so sorry if I got it wrong.
I'm looking at making a compressor unit for bass guitar, I have a circuit diagram but I fear it is rather outdated... It uses a VN10KM N channel VMOS transistor, which I am looking to either replace or upgrade and it also uses the good old LF351N ICs and I'm looking to upgrade those as well. If anyone has any suggestions for either of these then I am very grateful! ![]() Thanks, ainslie. |
#2 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Vn 10 may be replaced with BS107, check pinout. LF 351 is a JFET opamp, it is currently under production, or try any TL071 or CA3130 with some circuit tuning.
LW1DSE |
#3 |
I have tried using a CA3130 without much luck in the past so I'll give the TL071 a try and do you know where I can get hold of the BS107 as the supplier my school uses has that listed as discontinued.
Thank you for your help so far. |
| compressor diy | bigredlevy | Analog Line Level | 8 | 28th November 2010 06:30 PM |
| Tube Compressor | Ahmad_tbp | Tubes / Valves | 42 | 1st March 2010 03:49 PM |
| Looking into building a compressor | DeadSpeaker | Solid State | 10 | 19th October 2008 04:27 AM |
| Compressor / Limiter | whoandcar | Solid State | 6 | 12th May 2008 03:50 AM |
| This compressor needs more controlls | Domplotz | Instruments and Amps | 2 | 19th September 2006 10:04 PM |
