| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
The architecture of an amplifier will tell whether it is capable of being direct coupled, as not all are. If one is capable of being direct coupled then whether it is or not is a design decision so, as others have said, you have to ask about a particular amplifier or look at the circuit diagram. You have been given good advice.
#12 | |
![]() That clears things up for me for the most part. Last edited by JoeDJ; 29th March 2012 at 06:03 PM. |
#13 |
#14 |
I am hoping people at this forum who are more knowledgeable than myself would help me determine if my amplifiers are of the direct coupling type or not. One is a modified Decware Zen design with EL84 power tubes and 6922 tubes in the preamplifier section, plus rectifier tube for the power (pictures attached). I am considering ordering LD Mk III or LD Mk IV which I plan to use mostly with active monitor speakers (Yamaha HS50M) but may wish to connect it to this Decware Zen clone or perhaps t-amp from Arjen Helder. Any thoughts which of these amplifiers/active monitor speakers might use direct coupling please?
#15 |
Perhaps I should add that I also contacted the builder of the amp shown in previous message (still waiting for reply).
Peter |
#16 |
OK, I got the answers I needed. Apparently there is a capacitor used in between the stages in the design shown above so the amp is not directly coupled.
| Direct Coupled Amp | kianbach | Tubes / Valves | 1 | 8th January 2012 09:05 PM |
| capacitor coupled vs. direct coupled ouput | hugobross | Solid State | 11 | 21st January 2011 01:56 AM |
| 6sn7 direct coupled and transformer coupled | neazoi | Tubes / Valves | 3 | 23rd May 2008 03:30 PM |
| drift in direct coupled tubes | andrew_whitham | Tubes / Valves | 11 | 9th July 2007 09:19 PM |
| Can someone explain parafeed & direct coupled & a.c. coupled? | mwmitchell | Tubes / Valves | 2 | 11th September 2002 01:10 PM |
