| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
diyAudio Chief Moderator
I made a little thingy today that gave 2 extra Wi-Fi signal indication bars on my Smart TV located at the other end of the house 35ft from the router.
Found it here. I made just one because the router is facing the other way so an extra in the front would block the other. Still if your router faces the area of interest by its width, two are best. If printed in double size, gives 3dB more is said. A 1:1 print size Windsurfer plus positioning the front wand parallel to the floor gave best result to me, so no further hassle. Even if your router has no external antenna(s), a bigger printed parabolic booster about the size of the router can be placed close behind it and give results is claimed on the web. Here is it on my 3com. Directed, and turned on its back. Just a layer of kitchen aluminum foil stuck with UHU glue did the trick. |
#2 |
Nice find!
I will try it on some linksys access points I use on my business.
"Without deviations from the norm, progress is not possible" - Frank Zappa |
#3 |
You can use some clear thin film pages like those for projection slides even for outdoors I guess.
#4 |
For outdoors, the problem is not the antenna, but the access point to get damaged from weather (rain etc)
#5 |
What if wrapped in plastic bag?
It won't cut dBi but rain only?
#6 |
A guy at my old Apartment building was a wireless thief, he had a USB wireless antenna on a USB extension cord, and he placed it near the focus of a steel wok he had hanging in his window. He said it worked better than a "cantenna".
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley |
#7 |
They use kitchen sieves even.
| FS: KINDLE W/3G AND WI-FI | drptpcpe | Swap Meet | 0 | 26th February 2012 04:07 PM |
| Hello from WI | visualj | Introductions | 2 | 7th February 2012 03:37 PM |
| Let's invade ODDcon in Madison, WI! | Spasticteapot | Everything Else | 0 | 23rd January 2007 10:52 PM |
| WI Area DIY Event | PaulHilgeman | Multi-Way | 0 | 12th June 2003 01:20 AM |
