Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
lite audio mv-02 4 way remote control
Old 27th February 2012, 01:46 PM   #1
sb****33 is offline sb****33  France
Default lite audio mv-02 4 way remote control
Hi
After a lot of readings on diy forums, I finally succeded to get it work, but there is a problem:
- pressing input selector 1, 2, 3 or 4 makes potentiometer keep rotating conterclockwise endless until pressing +/- button. The only way to stop it is to connect R17 & R18 but then, potentiometer keeps turning if MUTE is pressed. Very likely MCU is bad.
Seller response:
1. When pressing input selector 1,2,3 or 4 the potentiometer keep rotating conterclockwise endless is to protect the amplifier. You are correct to connect R17 to disable this function.
2. The MCU is good as you press 'MUTE', the potentiometer will turn to zero volume
I have 2 suggestion for you:
1) there is a 'MON' button on the remote control, the factory setting is 'Normal' speed for the potentiometer, when you push the 'MON' button, the input select leds will off and it will become 'Slow' speed for the potentiometer. You can try to select the speed and see if it can slove your problem
2) Adjust the code switch a little bit to make the potentiometer receive the signal correct
Is it a joke ? I think he is kidding me. In fact, the code switch function is to activate relays as does remote push buttons 1-2-3-4.
What you think ? May it be fixed ?
Regards.
lite audio mv-02 4 way remote controlHide this!Advertise here!
Lite Audio MV-01 / MV-06 remote controlled volume/input selector roffe Parts 84 13th April 2018 03:13 PM
USAmps 50x REV 02 remote turn on blown Cr@sh Car Audio 4 13th June 2011 05:17 PM
Audio Note M-Zero remote control problem DIYNick Tubes / Valves 8 11th December 2010 05:09 PM
LiteAudio MV-01 motorize remote volume control jeffshort2000 Swap Meet 5 28th October 2009 08:06 PM
The Ultimate Remote Control Audio Project.. Please Help :) BoneDoc RC Subwoofers 25 10th February 2009 04:04 AM
