Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 23rd February 2012, 01:51 PM   #1
TroelsM is offline TroelsM  Denmark
TroelsM's Avatar
Default Philips surround speaker connector/plug
Hi
I've got a Philips LX7500R without the original speakers.
I'm considering building some simple speakers to use with the unit, but the speaker-connectors is not a standard I can identify.
I can find almost similar connectors on Ebay, but those are for round pins and I need a type for flat pins as shown in the picture.
If nothing else comes up, i might use small spade-connectors, but those will probably exert a lot of force on the contact-pins and no doubt break them quick.
The unit was dirt-cheap and I'd rather not spend more on plugs than on the entire dvd-cd-amplifier-thingy.
not looking for super-hifi-pure silver here. Just a solid connection.
Kind Regards TroelsM
Need more time...
Old 25th February 2012, 09:12 AM   #2
chris661's Avatar
Open it up, drill a few holes in the case, solder wires to each output, pass the wires through the case, add some kind of screw terminal. Dirt cheap, decent connection.
Chris
Old 26th February 2012, 09:14 PM   #3
You can buy small "spade" terminals that will fit the pins in those speaker connectors. Use insulated terminals, or add heat shrink tubing, to make sure they don't short together. (If you open up most cheap mini-system speakers, you will find that the connection to each driver is made by two spade terminals, one large, one small. The small one is about the right size to fit the Philips pins.)
Old 27th February 2012, 07:41 AM   #4
TroelsM's Avatar
Hi
Thanks for the reply´s. Would rather buy the right connector than modify the unit, but mostly to save time. Any connector would probably be better than the original.
Kind regards TroelsM
Need more time...
Anyone able to identify this speaker power connector? gadgetron Multi-Way 11 11th August 2011 04:55 AM
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
Orion speaker plug ECM Car Audio 11 23rd August 2008 06:05 AM
PPI Speaker Connector Rickdogg Car Audio 2 10th September 2006 08:15 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
