| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I purchased this Canon DC10 DVD-camcorder about 6
years back. It could record 25 minutes with one battery (BP-208) when it was new. Now even with a new fully charged battery it records only about 7 to 10 minutes. The recording is fantastic as it used to be. But it is eating battery fast. What could be the reason? For a solution I thought of purchasing a big size (fitting in my bag) lithium-ion battery (say 12volt) and then convert it to the required voltage using LM317 and then feed it to the camcorder through the dc in (where the AC adapter power supply goes). Will it work or I will just destroy the camera? Thanks for any suggestion. Roushon
S. Roushon |
#2 |
#3 | |
from some good shop and Canon is printed on it, expensive too! Still it could be. Just now checked the output of the adaptor with a multimeter: 8.2v, printed 8.4v 1.5A. Have some 2Ah 4.2v lithium-ion batteries, will series and parallel them to get 8.4v and lots of Ah. Can I connect this directly to the camcorder? Thanks Roushon
S. Roushon |
#4 |
The battery (BP-208) I purchased is from the following site.
Canon BP-208 Lithium-Ion Battery (850mAh) 0802B002 B&H Photo Roushon.
S. Roushon |
#5 |
What was the mAh rating of the original battery? B&H is reputable, but that does not rule out the possibility that somewhere in their supply chain counterfeit batteries were purchased. Also are you sure there isn't something wrong with the camera itself that is draining the battery?
www.kta-hifi.net |
#6 |
The original battery also has 850mAh as the new one. Do not know how
to check if the camera has a problem. It is working perfect as it was when new. The first battery which came with the camera is already dead (probably expired) and I cannot even charge it. Regards Roushon
S. Roushon |
#7 |
I wouldn't. The battery you linked to is 7.4 V, not 8.4 V. The latter value is the charging voltage, not the nominal voltage.
#8 | |
point where the adaptor plug goes not where the camcorder 7.4v battery is connected. Is it not OK then? Thanks and regards Roushon.
S. Roushon |
#9 |
I'm not sure. Is it possible to run the camcorder on external power without the battery installed?
#10 | |
That is why I thought of the solution in post 1. Regards Roushon
S. Roushon |
| Why is my gainclone eating fuses? | AJ Bertelson | Chip Amps | 16 | 12th February 2012 10:27 AM |
| ideas for a tube eating guitair amp | v4lve lover | Tubes / Valves | 11 | 20th November 2011 05:30 PM |
| amp bridging eating fuses, but load seems ok | da_madaxeman | Chip Amps | 3 | 28th April 2004 11:03 AM |
| Quad II eating valves? | Zombie | Tubes / Valves | 31 | 26th February 2003 05:29 PM |
| Mini DV Camcorder Battery | fcel | Everything Else | 0 | 5th December 2001 01:55 PM |
| Page generated in 0.14806 seconds (64.33% PHP - 35.67% MySQL) with 10 queries |
