| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I apologize if this has been covered previously, but I can't seem to find a relevant article.
I have built an amp6 chip amp and everything is great, except that I work from home and the amp is across the room from my desk. When the phone rings, I want to be able to hit an infra-red mute switch to toggle the mute pins on the amp. I know the right pins, I have IR sender and receiver components, I just don't know how to build a circuit that will toggle the connected state of the mute pins. Any guidance would be greatly appreciated. James Haney |
#2 |
It's not really clear what you've got.
If you already have a sender and a receiver, i.e. you press a button on the sender you get a momentary output from the receiver then that's mostly it. You get a TTL 'D' type latch chip (74xxx74). You connect NOT Q to D. You connect the momentary output to CLOCK IN on the latch. You connect Q to the mute input and you put power on everything, including the latch. Now every time you push the remote the mute will turn ON or OFF. If you need a bit more, google 'PIC micro IR decoder', it'll tell you all about codes, carrier frequency and where to get a programmed PIC universal IR decoder. |
| Transistor switch audio mute | TheFixer | Solid State | 21 | 24th August 2011 05:02 PM |
| Mixer Mute or On switch/function? | diymixer | Construction Tips | 1 | 4th August 2010 05:45 PM |
| Quiet Audio mute switch? | MondyT | Solid State | 18 | 19th September 2009 10:11 AM |
| Quick mute switch query.. | jethdub | Chip Amps | 3 | 19th April 2008 11:08 PM |
| Help on Preamp Mute Switch | BillyF | Tubes / Valves | 6 | 6th September 2004 12:05 AM |
| Page generated in 0.09720 seconds (63.71% PHP - 36.29% MySQL) with 10 queries |
