Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
LiPo batteries, help separating facts and myths
Old 2nd February 2012, 11:07 PM   #1
Peter Pan is offline Peter Pan  United States
Peter Pan's Avatar
Default LiPo batteries, help separating facts and myths
I'm building a very tiny practice guitar amp which will be powered by a 1500mAh Lipo battery pack. When I first discovered LIPOs I thought they were a Godsend, offering so much energy in a small space. Discovering I needed a "balance" charger to properly charge the pack was a little bit of an annoyance, but I've found several balance chargers pretty cheap so that wasn't a major concern. But what has become a major concern is that there are so many cautions related to LIPOs that my head is spinning. So I'd really like to hear from some people with some more actual practical experience to help me separate fact from fiction here.
1. I've heard that LIPOs can catch fire when you charge them. So I was hoping that if I charged a 1500mAh battery with only 500mA balance charger, it would make the likelihood of a hazard low enough to actually build the battery into the project, without having to make provision to remove the battery for every charge (not to mention having to charge it on something like a concrete floor!) Is my assumption safe? Are LIPOs really that dangerous that they could never be charged without removal from the devices they power?
2. I'd like to think that charging at a lower rate would be both safer and good for the batteries. But then I've heard you should NOT "trickle charge" LIPOs. Well, would 500mA charge for a 1500maH be borderline "trickle"? AND... is "trickle" charging really BAD for LIPOs?
3. I've heard that a 12V LiPO pack should fully charge to about 14V. But when my my charger indicates all cells are charged and balanced, the total is maybe 12.5 at best, with no load. Does this mean I'm not fully charging?
3. I've heard that if you discharge a 12V pack down to 10 volts, you'll permanently damage the battery. Geesh!!! Do I really have to build a sensing circuit that shuts down my amplifier to protect the battery when I reach a certain voltage? How critical is this, and what would be the real "damage" point for a 12V pack?
Thanks for any and all info.
Old 2nd February 2012, 11:30 PM   #2
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
1 - possibly. But luckily I have never experienced this yet (hopefully, never) a close call though when my charger did not stop and made the pack bulge a little. I would still recommend atleast a separate compartment for the battery.
2 - charging at a lower rate does not matter it just takes longer. What they meant with trickle charging is that once the charging cycle is complete, the charger should stop completely. there should be no current no matter how small should flow to the battery after that.
3 - Li Poly's are 3.7V/cell. with three cells in series, that is 11.1V nominal. four cells - 14.8V nominal. charfe termination is at 4.2V/cell that makes your 3cell battery sit at 12.6V fully charged with no load. 4cell packs will sit at 16.8V. The constant voltage mode of your charger should be around +/-50mV of 4.2V per cell. Go over that and battery life (% charge and cycle life) decreases dramatically.
there are two #3's :P - Yes, discharging a battery pack too low will damage it. It is usually around 3V/cell. I've read from various sources that the point of no return is around 2.7V/cell. Cell phone and laptop batteries have built in controllers that disconnect the load when over current, over voltage (that can also set the battery on fire) over discharge and over temperature occurs.
If someone finds any mistake please correct me. This is what I've been learning for several years now and working with Li-Ion and Li-poly batts.
Old 2nd February 2012, 11:45 PM   #3
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 LiPo batteries, help separating facts and myths
Sounds about right. I use 18650 batteries in various bits of hifi and for my bike light, your advice is all spot on.
Paradise Pre-reg PSU PCBs
Old 2nd February 2012, 11:49 PM   #4
hollbrow is offline hollbrow  United States
I use li-po batts a good bit with larger radio controlled planes and have also used them on an electric bicycle project- the cells they are selling these days are less prone to meltdown than the earlier ones- but it CAN happen. I would never put one on a charger and just 'shut the door and walk away'. You absolutely need automatic low voltage cut-off built into the circuitry. Once you drain a pack down past its point of no return you may as well dispose of it cause' it turns into a paperweight. If I wanted a small amp like that I'd build it- and use it- but I would be careful to adhere to the rules of li-po usage. By the way- li-po's are showing up in all sorts of things lately- the little radio control helicopters from air hogs and such use them- and those little portable "i-pod" speakers that charge from a usb port have a 1S li-po cell inside them.
Most cell phones and laptop batts are lithium or nickle metal hydride- but a lot of the same precautions apply.
Old 2nd February 2012, 11:53 PM   #5
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I don't understand why when charged it should stop completely. I always thought it itself stops consuming current when the current cycle is over, and can be held on constant voltage indefinitely long, no?
The Devil is not so terrible as his math model is!
Old 2nd February 2012, 11:56 PM   #6
Peter Pan's Avatar
OK, well then for something like a guitar amp (even a practice on), I'd better at least make a simple detector circuit to light a little warning LED at least, when the voltage gets down below 10V. I ought to be able to swing that with a simple Zener diode and an op-amp comparator. But I'm still really concerned about item #1! DJ... you mention that cell phones have circuits to shutdown on overvoltage or overcurrent. But still, if fire/explosion is a real danger, how could anyone sell a Cell phone with a Lithium battery? I sure would like to know if such a slow and controlled charge makes me safe enough from a hazard to let the device charge on my kitchen table, along with my Cell! :-)
Old 3rd February 2012, 12:00 AM   #7
GloBug is offline GloBug  Canada
Banned
Well I assume they are so stable when stored (voltage wise) it's not worth the risk over charging them. Some cells have protection, some don't. Protection failure would not be good.
Who want's Jiffy Pop?
Overcharging LiPo battery - YouTube
Over-Charging Li-Po cell - YouTube
Old 3rd February 2012, 12:02 AM   #8
dirkwright is offline dirkwright  United States
dirkwright's Avatar
I have a lipo battery pack in my motorcycle. It charges off of the normal alternator in the bike. No problems except it doesn't like the cold. I keep it in the house in the winter. I believe these are A123 type cells. They weigh like nothing...
Old 3rd February 2012, 12:05 AM   #9
Banned
Most lipos used for R/C use can say be charged at 1C, some maybe more but that is pushing them. 1C=equals discharge rate if I recall. Charging a battery at 1C is about the same time in theory as it takes to drain said battery, at it's safe operating limits
Charging at anything less then 1C is safer but slower.
For a hobby type battery pack you could just measure the individual cells, which is much more important than the overall voltage.
Some cell phones were just a single cell, which negates the issue of balance charging.
Old 3rd February 2012, 12:06 AM   #10
Wavebourn's Avatar
Lithium batteries themselves have thermal fuses inside. However, things sometimes can happen.
GM Volt Fire After Crash Said to Prompt Lithium-Battery Probe - Bloomberg
LiPo batteries, help separating facts and mythsHide this!Advertise here!
speaker cable myths and facts Bill poster Everything Else 1295 14th March 2014 02:44 PM
myths and facts on electrolytic capacitors in audio circuits krachkiste Solid State 92 8th July 2012 02:10 PM
LiPO battery charging Atilla Power Supplies 2 4th September 2009 06:37 AM
Separating bonded glass mmerig Everything Else 14 19th March 2008 02:27 PM
separating PSU for preamp woodturner-fran Tubes / Valves 4 7th February 2008 11:28 PM
