Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Long and Short Power Cables
Old 21st September 2003, 10:33 PM   #1
chris ma is offline chris ma  Canada
chris ma's Avatar
Default Long and Short Power Cables
It seems to be the norm to accept long AC cables for all electronics, but why it is not so with DC cables especially with high current?
Can someone please kindly enlighten me.
Best Regards,
Chris
Old 22nd September 2003, 04:10 AM   #2
haldor is offline haldor  United States
It's more about high voltage verses low voltage than it is AC verses DC. The reason why this is normally more of an issue with DC is that DC is typically used at lower voltages than AC (ignoring tube circuits).
To explain why, remember that Power = Volts x Amps. So when you cut the voltage in half you must double the amps to deliver the same power. For losses in a cable however, it is worse than this simple linear relationship. Restate the power formula using Ohms law (V = I x R) and you get Power = Amps^2 x Resistance. Double the amps flowing in a cable and you increase the resistive losses in that cable by a factor of 4. More amps requires either a fatter or shorter cable to deliver the same power at the same level of losses.
That's why long distance power lines use such high voltages (500,000V or higher). AC makes it a lot easier to convert voltage levels efficiently, so that's the main reason why power companies use it (plus you can make brushless motors with AC, a brushless DC motor is simply an AC motor with a DC to AC inverter).
Phil
Long and Short Power CablesHide this!Advertise here!
long-thin vs fat-short TL Henkjan Full Range 26 22nd October 2006 08:54 PM
Long cables from PSU to power amp OK? tcpip Solid State 21 11th October 2006 04:36 PM
Long excursion vs short Hayden Car Audio 19 5th March 2006 08:47 AM
Short vs. Long MLTL rdf Multi-Way 6 15th September 2004 05:41 AM
