| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#21 |
Since you didn't install the fan yet, install it as close to the room that you want to boost. The in duct fans don't have a lot of pushing power so you want to suck the air close to where you want it.
#22 | |
EUREKA! This beautiful little tab called "EAC" is an Electrical Air Cleaner, and I don't have one. I read the installation manual where it describes the operation of the furnace in detail. EAC is always on when the fan is on, 120V! ![]() One last question. When I plug everything in, can I just pull the breaker for the furnace (as long as it's not running when I do it, and cause ventilation issues)? |
#23 |
You can shut off the breaker or the service switch on the side of the unit. Either way the power will be off. Good find on that terminal. That will make it simple and you will have it for all seasons.
#24 |
I got the fan in, but the wiring is still in progress. Romex really isn't suited to hooking up to the control board. It's way too stiff.
I'm trying to stick with the wiring specs already inside the furnace, but that wire is really hard to find in small quantities. In the manual is says all wire inside the furnace must be rated to 105 C / 221 F, which excludes regular THHN wire. It's UL1015 PVC coated stranded stuff. Everything on the control board is between 18 and 14awg. The blower fan itself is on 18awg UL1275, but that is practically impossible to find, as far as I have seen. What kind of fuse do I need? |
#25 |
The booster installation manual says 14awg wire, but I would think 18awg is fine for in the furnace sine the big blower fan is 18awg and the booster only draws 0.4A.
#26 |
Net,
what is the total Flow and Return resistance of the 18awg cable you are thinking of using? Now apply that 0.4Aac to determine the voltage drop in the Flow and Return wiring. Express that voltage drop as a % of the whole 115Vac supply. Your regulations probably state that the % lost in the cable is limited to no more than 5% (This is just a guess). If your extra leg gives <2%, go ahead. If <1% then even better. But do watch your cable runs. Keep them cool.
regards Andrew T. |
#27 |
You need to run 14 because that is code minimum for residential. Just use some THHN from the board to a j box to connect the romex to. It will work fine.
#28 |
Got it, I'll do 14.
#29 |
All set up. I'll be observing everything over the next few days, but it appears to be working perfectly. I ended up putting a box in the ceiling with a switch. THHN runs from the furnace control board in flexible conduit, to that switch box, into Romex which runs through the ceiling to the fan.
Thanks all for the help. |
#30 |
Anytime.
| HVAC Experts out there? | lgreen | Everything Else | 7 | 2nd August 2009 11:41 PM |
| HVAC help anyone? | whubbard | The Lounge | 1 | 26th April 2009 10:34 AM |
| Custom Home Theater Project in New Home, Opinions appreciated. | thadman | Multi-Way | 5 | 20th November 2008 12:40 AM |
| what kind of relay is normally open but will close when triggered? | jarthel | Parts | 3 | 22nd August 2006 08:17 AM |
| Does this kind of switch/relay exist? | Hybrid fourdoor | Parts | 1 | 3rd January 2004 11:51 AM |
| Page generated in 0.11279 seconds (72.48% PHP - 27.52% MySQL) with 11 queries |
