| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I still have some UCD180ST modules lying around and would like to make a iPod "dock" with them. The only thing I´m not quite sure about is how to connect the iPod output to the balanced inputs of the modules in a simple way avoiding too much connectors/adapters etc. First method would be a cable (6 core). 2 times hot, cold and ground from the two amps soldered directly to a 3,5mm stereo jack. 2 x Hot to left and right out, 2 x cold and 2 x ground to iPod ground. This should work but is not really elegant. The second method would be to put a female 3,5mm connector isolated in the chassis (of the stereo amp), connect it in the way described above and use a short run (15-20cm) of cable with two 3,5mm jacks to connect the iPod. This way the ground and cold connections (4) would run for a short run of cable through the same core. Would this be possible or would this give hum or other problems? Thanks, William
een ooievaar is geen konijn want zijn oren zijn te klein! |
| Unbalanced to balanced transformer before UCD? | sharpi31 | Class D | 12 | 5th April 2011 07:07 PM |
| passive pre for UCD - balanced or SE??? | ssmith | Class D | 0 | 29th May 2006 08:57 AM |
| Page generated in 0.08781 seconds (54.65% PHP - 45.35% MySQL) with 10 queries |
