Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th September 2003, 01:46 PM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Best sofware for making a copy of a CD.
Has anyone ever subjectively compared the sound of different cd's ripped with different software?
Exact Audio Copy seems a lot better than say Windac.
CD's that EAC reports errors for, are just ripped seemingly without any problem by Windac. So my guess is that EAC is better than WinDac.
I will report on listening test in a few weeks time..But was wondering if anyone has done some subjective/objective tests.
Bas
Old 16th September 2003, 02:04 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
There was a thread about copying CDs: Why does CD sound better copied?
I'm using Nero and the difference is very small (quite acceptable). I still prefer my Pioneer Digital Audio burner.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 16th September 2003, 02:09 PM   #3
UrSv is offline UrSv  Sweden
UrSv's Avatar
Haven't compared sound at all actually.
Ease of copy depends on what the copy protection is if any.
Nero works well for normal stuff. So does Roxio Easy CD/DVD Creator.
The neatest I know is probably CloneCd but it seems new laws prevent it from being sold today:
http://www.elby.ch/
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 16th September 2003, 02:11 PM   #4
Thanks Peter,
The search function of diyaudio should be improved methinks.. (or I should learn to use it.)
It refuses a search of cd copying software because of cd
so I gave up
should be able to search with "cd copying software"
Bas
Old 16th September 2003, 02:12 PM   #5
UrSv's Avatar
Try cd* copying software...
UrSv
Old 16th September 2003, 02:13 PM   #6
I used "exact copy" to search + my name. As I read most threads, I remember some expressions, which were used in original thread and are helpful in searching. You can narrow choices by specifying section (digital) and using names of members participating in discussion (if it was you or you remember others).
www.audiosector.com
Old 16th September 2003, 02:14 PM   #7
I have always used Nero, but the audio extraction used to suck (early versions of Nero..3.x.x.x. ) so I gave it up very early. Now I just use Nero for burning. And EAC for ripping the WAV tracks.
On my system I could never really hear a difference..till I tried listening on Hans Kortenbach's system. With Phy speakers... Ripped with WinDac and burned with Nero..I absolutely sucked big time...sounding like a little transistor radio..no soundstage at all..flabby bass...
Bas
Old 16th September 2003, 02:17 PM   #8
I usually copy only the original CDs, always on a fly and with a single speed. It sounds good.
www.audiosector.com
Old 16th September 2003, 02:44 PM   #9
Dark Shadow's Avatar
EAC have a better ripping engine. What it do when you select the right option is that he re-read multiple time the same section to be sure to have the same value to ensure no error during the ripping. It slower but you have a better chance to get a perfect wav files this way. That why I'm using only EAC to rip and even encore my CD in Flac/OGG/MP3.
Francois
Old 16th September 2003, 02:51 PM   #10
Cradle22's Avatar
Hi!
Or you can use CDex to extract the tracks one by one, with paranoia mode turned on (Under Settings->CD-ROM->Ripping Method, turn on Paranoia - Full).
CDParanoia is a Linux-library for digital audio extraction, it does nearly the same as EAC, but is a bit faster (still, Full Paranoia is about 1/3 - 1/2 as fast as ripping without Paranoia turned on at all). There is no official port of this library to Win32, so the people of CDex seem to have proted the needed functions by themselve...
Since I also use CDex for making mp3 and Ogg Vorbis files, I use it for normal ripping, as well...
Bye,
Arndt
A Sacrifice For Freedom
copy a circuitboard! pdul Everything Else 19 25th June 2009 08:18 PM
PC Sofware, Need Help!!! kinser Everything Else 13 23rd May 2006 02:17 PM
Wich sim sofware are you using? reguinereg Multi-Way 1 12th January 2005 11:40 AM
LEAP 5 sofware lmic Multi-Way 0 21st January 2004 09:11 PM
CD Copy Inhibit spliffy Digital Source 2 13th January 2004 05:17 PM
Page generated in 0.10689 seconds (79.37% PHP - 20.63% MySQL) with 10 queries
