| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
Jer,
You seem to be missing what I'm saying. You are correct that you cannot do it the way I explained IF you use the POSITIVE OUTPUTS on both the left and right channel of the amplifier. If, however, you wire the inputs the way I explained and use the POSITIVE OUTPUT on one channel AND THE NEGATIVE OUTPUT on the other channel, it will work just fine, I promise. |
#12 |
Yes, you may have been confusing me in your explaination,
"the POSITIVE OUTPUT on one channel AND THE NEGATIVE OUTPUT on the other channel" If you are referring to the source output then yes you are correct. But this is were you had started to confuse me, "The + outputs of the amp will be IN PHASE, but the opposite outputs will be OUT OF PHASE" and, "connect the + output from the source to BOTH the + inputs of RIGHT and LEFT" I also definitely read this one wrong as well, " your speaker would be connected to + on the right and - on the left." You must try to be exact when explaining such things as sometimes things can get quite confusing,I know I have been there before and I have had to spend many hours retyping an explanation before. In my last explanation I had caught an error in #5 were I had used a (+) when it should have been a (-). he,he Sorry for the confusion. jer |
#13 |
Here's what I was saying:
1) Connect the + output from the source to both amplifier + inputs. 2) Connect the - output from the source to both amplifier - inputs. 3) Connect the speaker + to the Left + output of the amplifier. 4) Connect the speaker - to the Right - output of the amplifier. This will have the affect of summing the left and right amplifier power. It will do exactly the same thing as this: 1) Connect the + output from the source to the left amplifier + input. 2) Connect the - output from the source to the right amplifier + input. 3) Ground the - inputs of the amplifier. 4) Connect the speaker + to the Left + output of the amplifier. 5) Connect the speaker - to the Right + output of the amplifier.] I've highlighted the main difference between the two approaches in red, bold text. |
#14 |
No,I don't think that you are understanding correctly.
The signals of the amplifiers must be out of phase to work in a bridged mode. The - outputs of the amplifiers are tied to ground and bare no signal at all. Unless it is an amplifier that is already configured in a BTL mode as in Car audio devices, in which if that were the case this would bare no advantage at all. In a bridge configuration only the + outputs are connected to the load and are the only points that are active. The - outputs of the amplifiers are just GROUND the same ground that is connected to the input side (source) of the amplifier,A simple continuity test can confirm this. The only exception to this is when if the amplifier has a balanced input and is configured for unbalanced operation,where the - input (source) gets tied to ground as well. Otherwise it would be just a matter of swapping the - and + input signals on one of the amplifier inputs (source output) in order to run them in a Bridged mode. In a bridged mode configuration the output voltage will be twice the voltage of a what single amplifier can produce, With of course all things being equal. Therefore supplying 4 times the power output providing that the amplifiers can produce the current that is demanded from them. Or it will produce double the power of a single amplifier at an 8 ohm load into a 16 ohm load when configured as bridged . jer Last edited by geraldfryjr; 28th December 2011 at 08:36 PM. |
#15 | |
The OP was asking about connecting his factory head unit to an aftermarket amplifier, no? |
#16 | |
| Input signal and amp bias | vdi_nenna | Pass Labs | 14 | 10th September 2011 11:56 AM |
| headphone to car amp which takes balanced differential signal, please review circuit | emit | Car Audio | 2 | 23rd August 2011 05:35 PM |
| Controlling input signal current loops in balanced circuits. | Rescue Toaster | Pass Labs | 6 | 10th May 2006 05:19 AM |
| amp with single input can't amplify pulse signal,please help me | thanh | Solid State | 2 | 26th October 2004 01:56 PM |
| Balanced Signal Through Entire Amp? | G-Daddy | Solid State | 7 | 11th March 2002 08:46 PM |
| Page generated in 0.10699 seconds (73.07% PHP - 26.93% MySQL) with 10 queries |
