Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
A real apology from Andrew T.
Old 27th December 2011, 05:57 PM   #11
Pano is offline Pano  United States
Pano's Avatar
Over-quoting is my top forum pet-peeve. There was a thread on it, but few people seemed to care. Nice to see some more comments on it here. I've asked some prominent forum posters (via PM) not to do it. The answer was "I never do that" - only to see it again in the very next post!
As a Mod, I spend a lot of time removing the quotes of the entire previous post. A least it makes me feel like I'm doing something. Also spend a lot of time fixing bad quote tags.
I'd love to see the quote button moved to a less obvious place that would make it harder to just click "Quote" instead of "Reply". Might help a lot as it seems that many people just click Quote without thinking about it.
Take the Speaker Voltage Test!
Old 28th December 2011, 08:41 AM   #12
jitter is offline jitter  Netherlands
jitter's Avatar
Now that I'm writing a reply to a relatively short post that will likely end up right below Pano's post, I don't feel the need to quote (part of) it. If it were longer, I would have done so and broken it down into parts, and that's why it should remain possible. After posting I will obviously have to look at the thread again to see if someone beat me to it and edit if necessary.
I'm not sure I agree with moderators removing quotes from other people's posts when there's no rule that forbids quoting entire posts... Perhaps an amendmend of the rules is needed first.
IMHO, the move of the quote button to a less obvious place will only help temporarily as its new place will be found and remembered, unless... there will always be more effort needed to use the quote button than the reply button.
Old 28th December 2011, 09:01 AM   #13
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
You can interchange the URL that are pointed to by Quote and Reply buttons
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 28th December 2011, 09:33 AM   #14
poynton is offline poynton  United Kingdom
poynton's Avatar
The icon for a "Quick Reply" is already there just to the right of the "Quote" button but it is not obvious (no words)
Perhaps changing the "quote" button to a plain icon and the "reply" button to a "text button" would solve the problem. (is that what Regiregi22 meant ?)
But as Jitter says, there will always be those ...................
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 28th December 2011, 12:23 PM   #15
godfrey is offline godfrey  South Africa
Aaaaand, we have a winner!!! Here's Groove-T quoting his entire (immediately preceding) own post, without adding any further comment.
There should be a prize for that.
Old 28th December 2011, 12:25 PM   #16
regiregi22's Avatar
I have noticed something curious. If you look at the URL where the three bottom-right buttons are pointing, it is the same for both, so the action performed by those three buttons it's the same.
Is there a reason for this to be this way? Perhaps a coding bug?
Old 28th December 2011, 12:46 PM   #17
The buttons do perform different actions, so I guess there's JavaScript to handle the button clicks.
Old 28th December 2011, 12:52 PM   #18
a.wayne is offline a.wayne  United States
Sin Bin
Wow and all along i thought you guys only cared about THD, improper star gnds, toobs vs SS and NFB, this is deep ..s
Old 28th December 2011, 01:01 PM   #19
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Frequently, I contemplate why folks start these useless and utterly boring threads ?
Sometimes, the answer seems all to obvious.
Fortunately, when the nagging about posted or linked image size, proper Anglo-English spelling, punctuation, or forum rules, once again totally peed me off, I seek refuge in reading and posting at audio fora originating from Brazil, Argentina, France, Spain, Italy, Germany, Norway, Denmark, Russia, or Japan.
(not Dutch fora, those are stupendously annoying, and I've yet to read something of interest at a British forum)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 28th December 2011, 02:05 PM   #20
5th element is offline 5th element  United Kingdom
5th element's Avatar
I dislike it too when people quote ridiculous amounts, especially when it involves a large picture. I've also seen some people not even using quotes and simply copy/pasting the text from some previous posts and this makes it extremely difficult to actually read their replies.
I think there should be a set of guidelines on how to actually use quotes properly and then effectively.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
A real apology from Andrew T.Hide this!Advertise here!
Info Re Andrew King TheMooN Planars & Exotics 1 19th December 2007 10:53 AM
apology Vinnie R. Class D 6 9th March 2007 02:18 PM
Apology for commercial post Norman Tracy Swap Meet 5 2nd April 2004 12:54 AM
Combing effects: How real in "real" rooms? smeade1079 Multi-Way 3 10th March 2003 01:32 AM
Apology Peter Daniel Everything Else 0 5th December 2002 11:42 PM
Copyright ©1999-2017 diyAudio
