Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 14th September 2003, 08:46 AM   #1
PMA is offline PMA  Europe
PMA's Avatar
Default Distortion of human hearing
In the Pass Labs section there is a thread about human hearing. John Curl was describing his experiment with changing the slope of square-wave 5kHz signal from some 1us to some 5us and the audible effect of it.
I was told about experiments with addition of ultrasound signal, emitted by high-frequency el/ac. converter, to the audio band signal and audibility of this.
I would like to ask following question: what do you think about intermodulations inside human ear?
Old 14th September 2003, 09:11 AM   #2
It's there ... and used everyday in hospitals and audiology centres as a standard test. It's realetively easy to measure. You cab go to your docter and say ' I want my intermodulation distortion of my ears measured', he will probably go ... but if you tell him you got bad hearing and want a full check-up, you'll probably get your ntermodulation measured too ..
In the Netherlands many (all?) childeren get such a test, even before they can talk because it tells someting about the functioning of the inner ear without using a subjective patients feedback.
Thijs
Old 14th September 2003, 09:33 AM   #3
There is no doubt that Human Hearing suffer from Loudness Related Distortion Effects
There are well documented Loudness versus frequency curves available showing these effects being a form of Hearing Distortion in itself
At Very High Sound Levels, sensitivity to subtleties of musical sounds appear to become lost or masked
Examples are "Disco Night Clubs" or overly loud PA Systems at concerts
I feel certain that the Ear can overload, and in the process produce both Harmonic and Intermodulation Distortion, and maybe even Clipping at excessive Sound Levels
Many recent Pop Recordings are devoid of the subtleties that makes listening to recorded music pleasurable
This is likely caused by monitoring at excessive Sound Levels during the recording or mastering processes
In other words, the ears of the Recording Engineer, or Mastering Engineer, or both distorts making the final CD sound like "Crap"
Poul Kirk
Old 14th September 2003, 11:30 AM   #4
PMA's Avatar
Yes - I am thinking preferably about non-linear distortions, equal loudness contours are well known.
Old 14th September 2003, 06:52 PM   #5
vic2 is offline vic2  United States
The sensitivity of the ear is controlled by a couple of muscles: tensor tympani and stapedius.
Old 14th September 2003, 07:00 PM   #6
PMA's Avatar
Well - I shoul say why I was starting this thread. The reason is as follows: experiments show that extending the high frequency limit of the audio chain does not necessarily results in better subjective appreciation of such changes.
Old 15th September 2003, 04:40 AM   #7
Account Disabled
Do ears have a flat frequency response through the audio band?
Old 15th September 2003, 04:57 AM   #8
Steve Eddy's Avatar
Nope. Here are the ubiquitous Fletcher/Munsen, Robson/Dadson equal loudness curves.
se
Old 15th September 2003, 05:00 AM   #9
It is doubtfull that the Human Ear has a Flat Frequency Response, but how do you measure it
The Fletcher-Munson Equal Loudness Contour curves suggest that the response is not flat, and the ear has the grearest sensitivity for frequencies between 3 and 4 KHz
Moreover, the sensitivity to frequencies vary with Loudness
Hearing Loss usually manifests itself at the upper frequencies first, usually due to ageing
Sometimes due to Ilness of various types
Don't know too much about this particular subject
Hearing can also be damaged by very loud Industrial Noise Levels, or instantly if you stand too close to something exploding
Poul Kirk
Old 15th September 2003, 05:07 AM   #10
The one and only
Nelson Pass's Avatar
The ear has lots of mechanical faults, but don't underestimate
the neural power of the brain to interpret sound and music.
I think it's a lot more powerful than is generally given credit for.
Sensitivity of human hearing retroman Multi-Way 49 7th July 2009 10:31 PM
Harmonics above 20Khz - "Hi-Fi" and the limits of human hearing percy Everything Else 62 12th March 2008 05:27 PM
Human Hearing................. Gavinator68 Everything Else 25 26th January 2006 02:15 AM
Sensitivity of human hearing JDT Subwoofers 8 15th April 2005 02:36 AM
human hearing sss Solid State 123 8th September 2003 07:57 PM
Page generated in 0.10499 seconds (81.31% PHP - 18.69% MySQL) with 11 queries
