Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th December 2011, 01:12 AM   #1
Smile A Pyrrhic Victory of incredible magnitude.
$300,000 and a contested divorce worth of high-end audio wisdom!
High-End Audio is 50% physics and 50% voodoo.
Despite a nearly unlimited budget I was unable to match the signal quality of highly modified vacuum tube based equipment with highly modified solid state equipment.
Nelson Pass designs came closest.
Phase coherent speaker systems using first order cross-overs and only one driver per frequency range have no equal.
For CD input systems passive pre-amps are far better than any active pre, even with the best NOS tube compliment.
I am not capable of maintaining a vinyl collection, for those of you who are neat enough, I would suggest a dedicated phono pre-amplifier.
Natural dielectrics like silk and organic cotton are far superior to all the synthetics.
The secret formula for my amazing interconnects. Take a four nines silver ribbon wire with a natural silk dielectric with oil embedded at very high pressure (Dueland) and use it only for the positive. Use a six nines stranded copper wire with an organic cotton dielectric to the ground. Terminate with super expensive and equally cheap looking Eichmann silver bullets.
The amazing secret is to keep the two leads as separate as possible. They should only meet at the termination points. You can easily hear the difference in signal quality by slowly putting the two leads together. You will clearly hear the linear derogation in signal quality as you bring more of the two leads together. Putting the two leads together in the sleeve will result in the worst signal quality.
More to follow.
Old 15th December 2011, 02:19 AM   #2
Speakerholic
Cal Weldon's Avatar
Amazing?
More to follow.
Can't wait.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th December 2011, 02:38 AM   #3
I have never encounted a sarcastic Canadian, so I thank-you very much.
Next I will reveal the ideal tube compliment for speaker systems of 86db or more efficiency and who manufactured each NOS tube.
Old 15th December 2011, 02:57 AM   #4
benb is offline benb  United States
I can just hear the tube's compliment: "Nice speaker system you got there."
Old 15th December 2011, 02:59 AM   #5
kevinahcc20's Avatar
Well IMHO think the split is more like 5% physics and 95% voodoo.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 15th December 2011, 04:18 AM   #6
Enzo is offline Enzo  United States
Physics and voodoo combine to make... phoo.
Old 15th December 2011, 05:07 AM   #7
aardvarkash10's Avatar
So, I take it this is the voodoo component?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 15th December 2011, 05:15 AM   #8
I disunderstand.
Old 15th December 2011, 06:07 AM   #9
Previously: Kuei Yang Wang
ThorstenL's Avatar
Funny, I find the same thing. Running a very simple Push Pull Tube Amp at home now.
Playing here now is a simple 3-Way in a Stone Slab lined MDF Avalonis cabinet with a first order series crossover and pretty much timealigned drivers (depends a bit on how you sit... )...
I just threw out my Tube Pre and put my simple passive Pre back into the system, Grayhill input switch, 10K Noble Pot, Audio Note Silver wire for signal, goldplated 0.5mm bare silver for grounds.
Difficult one, as natural materials are hygroscopic and are not the best idea if you live somewhere where it is often quite damp (e.g. Good Olde England or Hong Kong)... If you live in the desert it is probably ideal...
I prefer air and the mechanical and chemical/electrical stability certain plastics (PE/PTFE) provide when used as support lattice for "in air" cables.
So, what do you as CD-Player/DAC?
I have a PC Source these Days (modified SPDIF Output from motherboard) optionally with an asynchronous USB to SPDIF converter and a Non-Oversampling TDA1541 DAC with a Tube output Stage...
Ciao T
Old 15th December 2011, 06:18 AM   #10
Francec is offline Francec  Australia
Banned
I have no idea what you are rabbitting on about.
A spreadsheet that can do spectral magnitude and phase gpapag Software Tools 7 18th December 2011 08:25 PM
Formulae for calculating crossover magnitude and phase based on component values alexclaber Multi-Way 33 19th May 2008 08:06 AM
A TDA2050 Victory but trouble with transformer Paswa Chip Amps 12 29th October 2007 04:20 PM
Question about transfer function magnitude. massappeal129 Subwoofers 4 16th August 2007 10:21 PM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
Page generated in 0.12182 seconds (86.24% PHP - 13.76% MySQL) with 10 queries
