| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Can they be rejuvinated? Don't tell me about zapping them because that
doesn't work. Nor will freezing do anything for them. They charge up to full voltage but have almost no current capacity. In a way this is like a dead lead acid battery they to will ofton act like they have taken a charge but have no current capacity. Again the tricks used on nicad batterys don't help them. |
#2 |
IMO, for single cells, if deeply discharging them and recharging a few cycles doesn't help, they're toast.
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 | |
But sometimes, they develop a sort of internal layering phenomenon, without any loss of electrolyte. In these cases, I have found that "desulfators" for lead batteries can improve the situation, and in some cases revive them. I am talking about the the ones that discharge an inductor into the elements. The pulse energy has to be commensurate with the size of the elements, otherwise that will kill them for good.
#4 |
Thanks I may try that but I sure some one made a dirt cheap desulfator.
And here I am talking about the $10 price range. |
#5 | |
Low Power Desulfator Info They can be built for less than 10$. I have made one with a variable inductor charging time, to reduce the pulse energy to levels suitable for smaller elements. It sometimes work - no guarantee
#6 |
BTW, I believe one of the failure modes for NiMH cells is internal breakage. They are somewhat fragile and dropping them can be the end of them. Possibly newer ones are better in this regard.
#7 |
Thanks I just ordered a few 555 timers and I can probably find
the rest of the parts in my scrap pile |
| Tango 10429 78% Nickle Output Transformer? | manp111 | Tubes / Valves | 16 | 24th January 2011 06:38 PM |
| Resistors, metal film or metal oxide? | gil1 | Solid State | 2 | 14th November 2010 02:16 PM |
| Battery Charger for 15V Li-ION Battery Pack ??? | Jan Dupont | Parts | 2 | 11th April 2009 02:18 PM |
| Metal dome should always go with metal cone? Is this a rule? | Jay_WJ | Multi-Way | 5 | 5th February 2007 06:53 PM |
| Metal Oxide vs flamme proof vs metal film | ostie01 | Parts | 28 | 26th June 2006 06:38 AM |
| Page generated in 0.10676 seconds (70.87% PHP - 29.13% MySQL) with 10 queries |
