| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#2 |
49 - for the 16th time
Hmmmmmmmm - I can't wait to read part II
Thanks for the tip bear!!!!
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod |
#3 |
<bump>
#4 |
I'm confused. Have you linked this so people can laugh at someone who believes he can hear things 130db below the signal or are we taking this seriously?
#5 |
Serious - open for discussion.
I think he is somewhat confused about a few points, but his goal is to bring some ideas that are not usually in the world of EEs to them... you can hear signals way below the noise floor... under some circumstances. Was hoping that folks would find this interesting to discuss... _-_-bear
#6 |
yes it is amusing/distressing to see "outsiders" (mis)interpretations of a subject you've spent some time studying – the different perspectives can be helpful in getting us to think about why we believe something
noise isn't a single number, you need the full spot noise vs frequency info, signal spectrum, knowledge of critical bands, masking, outer hair cell nonlinear amplification the numbers for the ultimate range are impressive, but most music is experienced in situations with relatively high nose floor compared to our threshold in quiet after minutes of accommodation, above the level that saturates the outer hair cell amplification an interesting extensively DBT tested result is seen in psychoacoustic compression algorithms, mp3 and better only use ~7 bits per critical band to achieve "transparent" coding of music |
#7 |
Dude, I don't have any of that knowledge at all, I just turn the volume up past "7" and let it crank! My friend says that until you get the knob to "10" it won't hurt the amp or speakers, right?
_-_-
#8 |
Both of them made from sands and metals. From my research, they have different way in driving loudspeaker, for example if a tube amp using high NFB they will sounds like not tube amps.
Thanks for that article, and tube amps are not the one with best sounds among all type of amplifiers. You may have tube sounds coming out of solid state also if you make it driving loudspeaker like tubes did. First the informations of differences between tube current source and transistor current source in any condition should fully collected. Then advance to the next step, to make transistors do the same. Heheh a waste may be. |
#9 |
No. I totally disagree. My tube amps with high NFB, low THD, low output resistance, sound like tube amps. It is the proof that tube amps sound warmer not because hey add some "warm" distortions. But because they don't add "Cold" distortions. My SS amps that don't add "cold" distortions sound also "warm".
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#10 | |
SS amps can sound very cold due to lack of distortion.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| Is high-end audio just lots of gimmicks and high price tags ?? | Trevor White | Everything Else | 497 | 20th June 2011 10:07 PM |
| Design high-End of brazil | Rafael L | Solid State | 0 | 9th March 2009 01:02 AM |
| high P LEDS DRIVERS ..electronic design required! maybe some $$ ?? | JinMTVT | Everything Else | 2 | 24th March 2008 08:24 PM |
| Latest Class-D atricle @ Electronic Design mag. | FastEddy | Class D | 0 | 17th October 2007 07:12 PM |
| Page generated in 0.13887 seconds (67.10% PHP - 32.90% MySQL) with 11 queries |
