| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#21 | |
Good design vs bad design makes more difference than tube vs transistor, IME. |
#22 | |
Nothing like "wonderful tube-like quality". That means, it is naked myth about "specific tube distortions" that are preferred by some "tube sound enthusiasts". But a tube amp with 0.01% THD that I designed, and built as a prototype, indeed sounds like a tube amp: soft, warm, transparent. My conclusion was, using of vacuum tubes allows to avoid "transistor harshness". Further experiments proved that indeed further minimization of distortions increases softness and transparency, up to the moment when sounds reproduced start being confused by subjective mind with real sounds. But such reduction of distortions has nothing to do with further reduction of THD by deeper overall feedback. It is mostly assistance to active devices to work in more stable regimes, with decreased variations of their parameters. Like, load of vacuum triodes on higher dynamic resistance, bootstrap of FET followeers, paralleling of BJTs to minimize effect of beta droop, design of wideband stages, and so on. And one more surprise: I've found that smoothness of transfer function means lower distortions than it's linearity. I.e. attempts to improve quality of an amp with smooth transfer function by decreasing of distortions applying feedback makes transfer function more linear but less smooth. It decreases THD, but increases audible distortions.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! Last edited by Wavebourn; 16th January 2012 at 03:22 PM. |
#23 |
Right again, as usual, Wavebourn.
#24 |
It's interesting that J. Gordon Holt, who was one of the early and most influential proponents of "tube sound," described it as bright and forward, not soft and warm.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#25 | |
Professional hypno-therapists use this well.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#26 | |
I have question, if you really do any good experiments. The question about tubes are many, but i just asking one, here: "why tubes always has tonal characters?" please explain its mechanism, and if you wish you may also explain what affected by this. |
#27 |
But the low damping factor that usually accompanies tube amplifiers gives a 'warm' frequency response regardless of the type of device (tube or SS). Maybe if it is supplemented with sufficient distortion, it can be brightened up enough to compensate.
#28 | |
If you want to argue, please find some other opponent. I just shared my own experience and my own conclusions, that are different from yours, and of course lead to different end results.
#29 |
There is not enough 'definition' here of a specific tube amplifier to be SPECIFIC how it sounds. For example, a Marantz 9 in triode will sound smooth, and a Mac 75 might sound 'bright and forward, yet a Mac 350 might sound almost as smooth as the Marantz 9 in triode, or more like a Marantz 9 in 'Ultralinear' mode.
#30 |
Ok, If you won't share yours, I also won't share mine. OK nevermind then.
Edit: The secret of tubes should not be revealed, you are right, Last edited by ontoaba; 16th January 2012 at 04:40 PM. |
| Is high-end audio just lots of gimmicks and high price tags ?? | Trevor White | Everything Else | 497 | 20th June 2011 10:07 PM |
| Design high-End of brazil | Rafael L | Solid State | 0 | 9th March 2009 01:02 AM |
| high P LEDS DRIVERS ..electronic design required! maybe some $$ ?? | JinMTVT | Everything Else | 2 | 24th March 2008 08:24 PM |
| Latest Class-D atricle @ Electronic Design mag. | FastEddy | Class D | 0 | 17th October 2007 07:12 PM |
| Page generated in 0.12953 seconds (79.75% PHP - 20.25% MySQL) with 11 queries |
