HDMI Audio Return to Toslink
Here is a solution to get audio return from web/ip based tv over over HDMI.
This 4x1 hdim switch with ARC can switch 4 sources and at same time convert audio return ( from TV to audio receiver) to Toslink. Also allows you to convert audio from HDMI to toslink, or switch up to 4 toslink sources independent of HDMI video selection.
NORCROSS, GA, November 23, 2011 /24-7PressRelease/ -- Octava Inc., specialists in HDMI solutions, announced the release of the HD41-ARC HDMI switch. The HD41-ARC enables HDMI switching and simple integration of ARC enabled Display with non-HDMI AV Amp.
The Octava HD41-ARC is a 4x1 HDMI + Optical + ARC Switch that enables owners of New ARC enabled Displays to listen to the TV's inbuilt Web/IP applications or Freeview tuner via their AV Receiver using an Optical connection between the HDMI Switch and the AV Amp.
In addition, 4 Toslink optical Audio Inputs allow users to switch from toslink sources independent of video viewing.
The HD41-ARC enables the user to select audio from HDMI, Optical or ARC.
Features:
- 4 x HDMI Inputs
- 4 x Optical Inputs
- 1 x ARC enabled HDMI Output.
- 1 x Optical Output
Select HDMI, Optical or ARC Audio no matter which HDMI Source you are viewing.
Push Button, IR, Smart SCAN plus RS232 control.
Rear mounted IR jack for use with an IR Extender head (available separately).
3D compatible with Blu-ray and 3D Broadcasts.
Rear USB port for Firmware updates.
Supplied including Optional Rack mount lugs.
Free PC App. allows control from your PC
