Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 9th September 2003, 12:18 PM   #1
Default Passive Pre Amplifiers
I am a little confused about Audiophile Terminology
What exactly is a Passive Pre Amplifier?
As I understand and believe, a Pre Amplifier is a device with Gain, to lift the Audio Level from a Microphone to a usable Line Level, or a Phono Pre Amplifier, a device with Gain to lift the level from a Pick Up Phono Cartridge to Line Level, and at the same perform RIAA Frequency response compensation to render the resultant Audio Frequency Response Flat or Level
Audio from Cassette Decks, DAT Players, CD Players etc comes out at Line Level, and is required to feed Line Level to the associated Power Amplifiers
Maybe the "Passive" Pre Amplifier is provided with a Gain Control, and "Horrors" Tone Controls, AKA Equalization, and usually also Input Source Switching
With this provided, it is no longer "Passive"
Maybe a better name for such a unit is a "Control Unit"
I am still confused about the term "Passive Pre Amplifier"
Only a piece of wire is a passive
Any clarification
Poul Kirk
Old 9th September 2003, 01:40 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
You are right!
In theory a passive preamplifier is just a volume control pot (and in some cases also an input selector)...
Nothing to do with the word "Amplifier"
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 9th September 2003, 02:14 PM   #3
moamps is offline moamps  Croatia
Transformer passive preamp doesn't need power (with usually 3 or 6dB voltage gain).
Old 9th September 2003, 03:03 PM   #4
Brett's Avatar
It's simply semantics.
You are correct that Control Unit would be a more accurate description as a Passive Pre usually only contains an attenuator and a source selector (+ perhaps a mono sw and phase). However the term preamplifier has become known as the control unit so in audiophool terminology a passive pre is the same thing, lacking the active gain stage.
Old 10th September 2003, 04:50 PM   #5
mrfeedback's Avatar
Passive Preamp means Passive Attenuator, with maybe additional switching.
There has been discussion previously of a Passive Pre using a fixed series resistor and variable shunt resistor to provide level control - Fred Dieckmann's Attenuator
Of course this does not follow A-law curve, but in practice I have not found this to be objectionable.
Eric.
I believe not to believe in any fixed belief system.
Bi-amplification to Dx Amplifiers, a passive input filter destroyer X Solid State 53 17th July 2009 05:16 PM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
Many smaller amplifiers vs. bigger amplifiers. djdan Solid State 9 17th September 2002 04:40 PM
Page generated in 0.08264 seconds (78.10% PHP - 21.90% MySQL) with 10 queries
