Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th October 2011, 09:56 PM   #1
ODougbo is offline ODougbo  United States
Question Kyocera 710CX CD player
Does anyone know what screw size is used for transport a vintage Kyocera CD player?
There was a small screw that went in the transport mechanism that I lost and need to ship it.
Old 27th October 2011, 10:36 PM   #2
That's a darn obscure question.
There are two screws holding a sliding plastic clamp on the bottom of the unit that locks the transport. The screws are designed to bind up on removal, so they shouldn't fall out or be lost to begin with. If you don't have the plastic piece, the screws may not help you. That said, the screws are M3x0.5 with a length of 10 mm under the head (9.6 mm measured) Truthfully, this doesn't sound like the answer to the question you asked, but I don't know of any other small screws involved in transporting the unit. The plastic piece acts, I think, as a spacer when you lock up the transport, so it doesn't bottom out flat to the chassis. I'm not sure if you can lock it up without damage without the plastic piece, but it would certainly be destroyed if not locked for shipment.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 27th October 2011, 11:38 PM   #3
Unhappy Plastic Piece
Conrad,
I think you hit the nail on the head, there may have been a plastic piece - now that you remind me. (It's been 20 years)
I hate moving it, there is something in there bumps around alot when it is moved. A nice sounding player though ~ thanks.
btw, I have the box and the foam packing blocks, no plastic piece.
Old 28th October 2011, 01:19 AM   #4
It is a darn fine sounding player, giving anything today a run for its money. If you can find some plastic strips the width of the slots, maybe 1/16 inch thick, drill a hole near the end, then slide them in to act as a washer between the internal guts and the chassis bottom when you install the screws (gently). IMO, the original red plastic piece was way more complicated than the task requires. You just want something that you can hold on to so it can't slip inside and require a search and rescue mission!
Nice Kyocera DA-610 CD Player! $75 OBO adowd Swap Meet 0 26th June 2010 06:43 PM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 08:29 AM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
Stand Alone CD Player vs. DVD Combo-Player Tom D Digital Source 0 2nd January 2003 04:08 PM
Page generated in 0.08292 seconds (70.74% PHP - 29.26% MySQL) with 10 queries
