| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I know this isn't the right forum, but i figured this place gets a lot of views. So...I'm trying to fix a Cadco bread oven, the heating element never gets hot. I tested the element, it works when connected to a power source.
This contactor was supplying power to the element, and obviously burnt up, hence the element never getting hot... The thing is, this is a General Electric Contactor, and its an Italian made oven, so that leads me to believe this was already replaced once. (The oven is 3 years old, out of warranty, been serviced once) So what would cause this to happen? Too much voltage going to the magnetic coil? That would be a circuit board problem then, correct? anyway, the contactor needs to be replaced, should I upgrade that now? (it's already a 230 NOT a 24 volt contactor...) |
#2 |
#3 |
I'd check the voltage going to the coil, if that's ok I'd guess the replacement switch was underrated or installed wrong.
#4 |
could just be mechanical vibration that over time causes the coil wires to rub together, eventually getting through the insulation- and then it's over quick-
but I'd also check the supply voltage. And I would not be too surprised at a GE part inside. It could have been repaired before with the identical problem, and had the original part replaced with an original part, and had it fail the same way...again. A comment on the general decline of parts quality is withheld.... But, since you probably don't know what the 1st repair was, myself...I would just replace it with an exact part and see how long it holds, but do check the supply voltage. If the coil shorted it may have caused some more damage. |
#5 |
Are your certain that the coil is rated at 230 volts and not 120 volts?
Obviously the coil has over-heated. A bit of series resistance in the circuit feeding the coil might provide some future protection against failure.
Frank |
#6 |
What sometimes happens is that a bad screw or other connection causes overheating of that connection, plastic and wire insulation can melt then, in some cases the plastic and insulation carbonizes becoming a conductor leading to even more heat... If the wire insulation of the coil melted then several windings could have been shorted causing a "chain reaction" and resulting in a total burn out...
Here in Belgium we also have a 3 phase system where there is a higher voltage between the phases (for example 380V) and a lower voltage between each phase and the neutral wire (230V) there are also other voltages possible with a 3 phase system, so when we buy a second hand machine the first thing we do is check if the connection is suited for our 3 phase system, but it did happen already that we missed and a motor or heating element burned... |
#7 | |
The other two hots feed the heating element, which makes it 240V. I'm pretty sure the contactor is rated for 240V, but the coil itself is only 120V.... |
#8 |
#9 |
are there any numbers on the switch/coil? that contactor is sold separate from the switch
#10 |
really? i thought it was all one unit when purchased new...here...
IEC Mini Contactor, NonRev, 120VAC, 12A, 3P - Magnetic Contactors - Starters and Contactors - 6KYP4 : Grainger Industrial Supply |
| Why burn in? | sianturi | Multi-Way | 17 | 1st January 2010 11:22 PM |
| burn in of components | jitter | Parts | 25 | 30th April 2009 07:47 AM |
| ge lighting contactor | engel dela pena | Everything Else | 1 | 2nd January 2009 12:14 PM |
| Mosfet burn | jegandren | Power Supplies | 2 | 24th July 2008 04:06 PM |
| Help! May I burn driver this way? | dw1narso | Multi-Way | 10 | 4th April 2008 06:48 PM |
| Page generated in 0.12105 seconds (75.97% PHP - 24.03% MySQL) with 11 queries |
