| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello all!
I need help about HHO gas installations in the car. Some description of how this system works to the car. thanks |
#2 |
hho = water.
Water in gaseous form is steam. Just build a heater that turns water into steam. If you want separate H from O then you need two gases as the output. Hydrogen is one output and oxygen is the other output. For this you need to build an electrolysis machine. But, ask your insurance company if they will cover the risk of an oxygen production plant in your car, or in your garden , or in your house. Hear what they say after that long cough/laughter/sound of falling off the chair !
regards Andrew T. |
#3 | |
#5 | |
Oxyhydrogen - Wikipedia, the free encyclopedia |
#7 |
Stoichiometric hydrogen and oxygen mixture can be rather explosive. As others have said, to produce it requires as a minimum the same amount of energy you get by burning it again. System losses make it worse than this. I suppose the only benefit you might get would be if you use solar electricity to produce it - this is (sort of) free.
#8 |
Yep, "sort of". This may no longer be 100% true, but in general no solar cell ever produces the amount of energy that it took to make it. A useful exception is the solar cell called a tree. It collects for a very long time, then you can burn it to get almost free energy. It can even warm you two or three times over if you have to cut and stack it before burning.
I used to be an audiophool like you but then I took an arrow to the knee. |
#9 |
I believe modern solar cells are genuine power sources, although until recently they were just a way of recovering some of the energy used in making them.
Trees are good. Are you suggesting we use wood-burning steam cars? |
#10 |
| Where are able to find tutorials or more information on this topic: HHO GENERATOR ISU | formula 22 | Equipment & Tools | 4 | 8th October 2011 02:42 PM |
| Gas Ampzilla | mharry | Solid State | 22 | 6th August 2010 07:08 AM |
| GAS Thaedra | d3imlay | Solid State | 45 | 13th March 2009 01:37 PM |
| Using Gas Regulators | alexmoose | Tubes / Valves | 8 | 21st December 2006 06:48 AM |
| Page generated in 0.11347 seconds (75.93% PHP - 24.07% MySQL) with 10 queries |
