Transfer Funtion of the given circuit ?
Please give me the transfer function of the following circuit. Where R1,R2,R3,R4 and R5 are not equal.
it actually "safer" to explicitly include op amp gain "A" and derive the equations
you can always take the limit as A goes to infinity later - but by assuming it from the start you may save a term or two in the calculations or you may have your solution "blow up" from the infinity you are implicitly carrying around
the op amp Howland current source is a favorite nasty problem set for those not understanding the "null injection" implicit infinity
@DF96
I am not a student in any institute so do not expect any Marks.
@SY, jcx
Thank you, I solved it using superposition theory.
R1 and R2 forms voltage divider for Non-Inv voltage. R3||RD forms Rg and R4 forms Rf. So Non-Inv, Inv output voltage will be
Vninv = V1*[R2/(R1+R2)]*[1+{R4/(R3||RD)}]
Vinv = V1*-(R4/R3)
Vout = Vninv + Vinv
Now you got it. 🙂
Vninv is non-inverting output voltage which is equal to
Vinput * Resistor-Divider Output * Non-Inverting Gain
Vinv is inverting output voltage which is equal to
Vinput * Inverting Gain
Final output voltage will be sum of Vninv and Vinv
Am I correct ?
I fell into the same tiger trap as DF96.
Vinv = input voltage at -IN pin.
Vninv = input voltage at +IN pin
Silly me for reading what it said,
Instead I should have reverse engineered the given equations and realised that Voutinv=Vinv and Voutninv=Vninv are the only way to make your equations work correctly !!!!
