Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Transfer Funtion of the given circuit ?
Old 10th October 2011, 08:43 PM   #11
DF96 is offline DF96  England
OK, I see how you have done it. Split node 1 into two independent inputs, then add the result. What confused me was your nomenclature: I assumed that Vninv was the voltage at the noninverting input, when in fact it is the output due to the input at the noninverting input.
Old 11th October 2011, 08:55 AM   #12
sameerdhiman is offline sameerdhiman  India
Now you got it.
Vninv is non-inverting output voltage which is equal to
Vinput * Resistor-Divider Output * Non-Inverting Gain
Vinv is inverting output voltage which is equal to
Vinput * Inverting Gain
Final output voltage will be sum of Vninv and Vinv
Am I correct ?
Sameer Dhiman
Old 11th October 2011, 01:02 PM   #13
Yes.
Old 11th October 2011, 01:23 PM   #14
I fell into the same tiger trap as DF96.
Vinv = input voltage at -IN pin.
Vninv = input voltage at +IN pin
Silly me for reading what it said,
Instead I should have reverse engineered the given equations and realised that Voutinv=Vinv and Voutninv=Vninv are the only way to make your equations work correctly !!!!
regards Andrew T.
Transfer Funtion of the given circuit ?Hide this!Advertise here!
Getting transfer characteristics lcsaszar Tubes / Valves 1 13th August 2008 12:14 AM
Need transfer software for my Ipod!!! michael9827 Instruments and Amps 3 14th June 2008 05:02 PM
transfer function jenks Solid State 31 24th April 2008 09:28 PM
Transfer Function jclouse Multi-Way 22 1st July 2006 02:19 PM
Transfer functions? oracel Multi-Way 15 23rd October 2004 02:34 PM
Copyright ©1999-2017 diyAudio
