Audio Y Splitter Not Splitting Signal Properly - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th September 2011, 06:15 PM   #1
Default Audio Y Splitter Not Splitting Signal Properly
Hi all,
I have a setup where I take a stereo audio track created in Matlab (L track contains signal, R track contains noise) and present it out through the audio jack on my computer using a 1->2 RCA cable. This RCA cable should split the digital stereo track into 2 separate analog mono tracks for further processing. When I silence one of the analog cables (by unplugging either the L or R) in an attempt to either completely remove the signal or the noise, what I find is I'm left with a track that contains both signal and noise. If I unplug the L track, the remaining track tends to have louder noise than signal, whereas if I unplug the R track, the remaining track has a louder signal than noise. This suggests to me that the signal is somehow being premixed before splitting the stereo track into 2 analog mono tracks. I'm fairly certain the problem isn't the 1->2 RCA cable because I've tried using a simple 3.5mm headphone splitter instead and it does the same thing. I am working on Windows 7 with a Creative SB X-Fi sound card with the following details:
Driver Provider: Creative
Driver Date: 7/7/2010
Driver Version: 6.0.1.1348
Driver Signer: Microsoft Windows Hardware Compatibility Publisher
I would really appreciate any ideas for why the signal is behaving this way.
Jeff
Old 27th September 2011, 06:46 PM   #2
diyAudio Member RIP
Why are you sending two tracks, one noise only to a mono output ?
I don't understand you post. seems like you've got autogain
on your inputs which ups noise if the input is unplugged.
rgds, sreten.
Old 27th September 2011, 06:51 PM   #3
sofaspud's Avatar
...present it out through the audio jack on my computer using a 1->2 RCA cable. This RCA cable should split the digital stereo track into 2 separate analog mono tracks for further processing.
I would expect a 1->2 RCA cable to behave pretty much as you describe.
A stereo male to 2x stereo female, or stereo male to L and R female?
If you're fairly certain the signal isn't being summed by the cables, that leaves the computer itself as culprit.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 27th September 2011, 07:10 PM   #4
Frank Berry's Avatar
You should check the setup of your sound card.
Make sure that the output is set for stereo speakers.
Disable all effects.
Frank
Old 28th September 2011, 12:25 AM   #5
wwenze is offline wwenze  Singapore
Run X-Fi control panel, disable CMSS.
Old 28th September 2011, 12:40 AM   #6
revboden's Avatar
yeah, your dealing with some kind of spatial enhancer. turn off all effects
Old 28th September 2011, 12:43 AM   #7
Enzo is offline Enzo  United States
And if your audio card has any mixer controls, make sure both L and R signals are panned all the way to the extreme L and R setting.
Old 28th September 2011, 12:51 AM   #8
The relative levels are critical as regards deciding what is going on, but 3.5mm stereo jack sockets (and plugs I guess), have an intrinsically high level of crosstalk, IIRC. You can probably find the figures on nwavguy's blog.
Old 28th September 2011, 08:28 PM   #9
Default Problem Solved
Thanks to everyone who responded!
The problem was that the sound card was set to Game Mode, so I disabled all sound blaster effects.
Jeff
Splitting AES/EBU Signal KCCT82 Digital Source 22 8th August 2016 10:43 PM
Audio signal splitter (for preamp) Krislarsen Analog Line Level 3 21st February 2006 12:25 PM
splitting a digital signal bser Digital Source 4 26th October 2005 05:43 PM
splitting a signal Winnie Multi-Way 2 17th October 2003 02:12 PM
Copyright 1999-2017 diyAudio
