Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Closed Thread
Old 19th September 2011, 01:18 AM   #101
BFNY is offline BFNY  United States
From Bruel and Kjaer book "Architectural Acoustics" pg. 16-17
Definitions of acoustic Energy Density, Intensity, and Intensity Level
Old 19th September 2011, 01:21 AM   #102
From Bruel and Kjaer book "Architectural Acoustics" pg. 18-19
1.16. Sound Pressure Level
1.17. Sound Power Level
In case anyone is still confused about the difference
Old 19th September 2011, 01:27 AM   #103
sreten is online now sreten  United Kingdom
Originally Posted by SoNic_real_one View Post
And to produce those 3dB in power we need 3dB in voltage.
Hi, And another person who simply does not understand the concepts, the above is simply not true, rgds, sreten.
3dB in power always implies 1.5 dB (x1.4) in voltage ratio, whether it is actually true or not, for the actual case.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 19th September 2011, 02:05 AM   #104
hi, fairly cluelessly you can't work out they are exactly the same thing, rgds, sreten.
Old 19th September 2011, 02:07 AM   #105
Fairly cluelessly you can't work out they are exactly the same
thing, as it seems so the fairly clueless original author cannot,
or if he does know he pedantically neglects to say so, pathetic.
rgds, sreten.
Old 19th September 2011, 02:12 AM   #106
From Bruel and Kjaer book "Acoustic Noise Measurements" pg. 32-33
More on SPL, SWL, and Decibels
Old 19th September 2011, 02:17 AM   #107
From Bruel and Kjaer book "Acoustic Noise Measurements" pg. 34-35
Math behind the following topics -
Theory on adding 2 equal sources - independent and uncorrelated page 34,
Theory on adding 2 equal sources - Correlated, conclusion on bottom of page 35
Old 19th September 2011, 02:57 AM   #108
rgds, sreten.
So...I'm clueless, the Bruel and Kjaer author is clueless, and you are right?
Sreten - You continue to confuse the definition of *acoustic intensity*, the power passing through a unit area in space, which IS proportional to the square of the sound pressure in the far field, with the definition of *sound power*.
Also, there's no reason to ever convert "back to power" when dealing with voltage or pressure dB's. No one ever does this. Practically everyone figures out if the dB units are power or not, and then uses 10log or 20log as appropriate. In the real world, that is.
I suggest people read the Bruel and Kjaer reference material for a good understanding of the subject.
Bob
Old 19th September 2011, 03:20 AM   #109
Speakerholic
Cal Weldon's Avatar
Thread temporarily closed
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Closed Thread
Level-dependend Sound Quality by certainly Bass Drivers - very bad sound at low level tiefbassuebertr Subwoofers 11 3rd March 2012 10:54 AM
sound level problem moochinazz Car Audio 6 21st April 2011 09:16 PM
Level-dependend Sound Quality by certainly Bass Drivers - very bad sound at low level tiefbassuebertr Multi-Way 1 2nd April 2010 04:12 AM
Sound level meter Leolo Equipment & Tools 4 6th January 2010 06:58 AM
Sound level SeigneurVoland Multi-Way 5 24th January 2005 04:39 AM
Page generated in 0.14095 seconds (70.54% PHP - 29.46% MySQL) with 11 queries
