Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
need help deciphering circuit for foot control.
Old 15th September 2011, 03:36 AM   #1
ching0n is offline ching0n  United States
Default need help deciphering circuit for foot control.
I'm going to build a pedal for my tig welder and am having trouble with a modified circuit I want to try. I've deciphered the 'simplified' circuit by now (pg.3), but would like to build the more complex one. Basically the one on page 4, I assumed the author meant for the builder to provide new headers, but where these connect to I have no idea.
The description is as follows:
Here is an update to the 91811 schematic. This
contains the OEM version of the machine [pages
1,2], my original modification for external heat and
timing control [page 4], and a substantially simplified
circuit providing external heat control alone [page 3].
This simplified external heat mod involves no surgery
to the control board. Tie-in to the PWM controller
is achieved by disconnecting the 3-pin connector from
the existing front panel 10K heat pot and routing it to
the board containing the added circuitry. This board
will supply it's own 3-pin cable/header which will then
connect to the original 10K pot PCB. The worst of
the modification is extracting GND and +12V from the
main board which can be found on the voltage
regulator U5, at pins #2 and #3 respectively. With
some soldering skill one should be able to make the
two connections without needing to unmount the
main PCB from the heat sink.
What I can't figure out is if the 'timing' he refers to is to control the 'shielding gas solenoid' or the heat timing (like some sort of pulse control). Also, the pedal I want to retrofit only has 15 degrees of motion on the pot, however I don't think this presents a problem since I'm guessing the signal is amplified; however, should I worry about the pot reading '0' ohms at any given position or is it ok for it to read some 'low' and 'high' value relative to one another?
To conclude, I read somewhere that this modification somehow takes care of interference that may be caused by the machine operating (dunno how); so my concern is can I build the circuit inside the pedal (extending whatever leads to the machine [will shielding be required?]) or should I keep the circuit near the machine?
Any and all help will be very much appreciated.
need help deciphering circuit for foot control.Hide this!Advertise here!
CLONE Usher CP8571 -Help deciphering crossover xelos Multi-Way 1 1st June 2011 08:49 PM
Help deciphering crossover percy Multi-Way 26 15th May 2011 03:58 PM
deciphering my x-over need experienced help cmitch Multi-Way 11 21st November 2005 12:05 AM
IR MOSFETS -- part # deciphering rif Parts 2 6th May 2004 08:05 PM
Level Control Circuit palesha Solid State 3 13th August 2002 07:10 PM
Copyright ©1999-2017 diyAudio
