| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I had built up a few cascode CCS's for a gas tube shunt regulator, running at 82mA. I have some pcb's used for a standard heatsinked design which has
worked well at lower currents. What I found, at least with this latest batch of 10M45 IC's, is that the Vgs was very low, around 0.5V for 82mA. The net result was that the bottom DN2540 was unable to provide this low a voltage, and the 10M45 would not reach the desired 82mA target. So the problem is that the bottom device was saturated due to insufficient Vds. This got me thinking about how to provide more Vgs to the top devices. More voltage is also better for the bottom device, which decreases in output capacitance as the voltage increases. I have attached a possible design with paralleled upper IC's. Running them in parallel now requires less current, which equates to higher Vgs. It is true that they may not share current equally since you force the same Vgs, but it will certainly be improved over trying to run only one. The two devices can even share the same heatsink without isolation pads. Particular people could even screen for equal transfer characteristics at the desired operating point. Yes, you could just parallel two separate cascodes, but this takes four devices instead of three, along with separate adjustments. The DN2540 can easily run over 100mA, given enough Vds. I have used up my IC's, so will have to order more in order to test it out, but it seems to me this will work, even three devices. Thoughts? |
#2 |
Oh yeah, forgot to mention the most important part: I placed a Bybee in series with the bottom device, and the sound became more 'liquid'.
#3 |
Why Zeners instead of reverse-biased "normal" diodes? And you might want to put them on the "far" side of the gate stoppers.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
Just to protect the gates in both directions- ESD, transients, static conditions, whatever might put them at risk. When used in power supplies I have had these CCS's schmoke before; ever since installing the zeners I haven't had any problems.
I could put them on the other side; not sure it would make much difference either way unless there is concern about oscillation due to zener leakage effects? |
#6 |
I'll move them in the next pcb revision.
So I assume the method with one lower device driving two, three, or four uppers will work, up to the IDSS of the lower device. |
#7 |
Update after a few months:
Finally got around to building and testing the scheme. Works well, to over 100 mA, when the single upper device could only get to maybe 70 mA. This is good news, as the non-cascoded version would let through just a tad of 120 Hz ripple that I was able to measure. This new cascode should clean up that last bit for a clean PS. |
| DN2540 + LM317 cascode CCS? | rongon | Tubes / Valves | 6 | 26th May 2011 11:55 PM |
| Best voltage reference device for a cascode BJT CCS? | ray_moth | Tubes / Valves | 2 | 1st July 2009 09:38 PM |
| Help on Cascode DN2540 CCS | swordsman | Tubes / Valves | 1 | 24th December 2008 04:48 AM |
| Pentode Cascode CCS | croccodillo | Tubes / Valves | 3 | 31st August 2006 07:49 AM |
| Use od LED for CCS and cascode stages | Mambo | Solid State | 14 | 10th September 2003 08:00 PM |
| Page generated in 0.09610 seconds (75.07% PHP - 24.93% MySQL) with 11 queries |
