| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
A couple days ago the rubber protective boot on my cell phone came off, I was going to sell the phone anways but I should fix it up first, don't ya think? It's smooth plastic and foam, looks like it was adhered originaly with some kind of sticky sheet, but it got hot one day and came loose. So, what kind of glue (innexpensive and locally available, I'm not ordering stuff) should I try to put it back together with?
Thanks, Keith |
#2 |
I would try super glue. but my guess is you don't want to try that.
so maybe a epoxy? you can't good old rubber cement... well i'd look around and make sure it's safe with what your using it for (trust me i found out the hard way.) well i sure i told you nothing new...Sorry |
#3 |
contact cement....super glue and epoxy will harden rubber
#4 |
use the stuff they apply when they fix ur shoes?? It's those kind that people sniff...inhalant abuse...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#5 |
Alright, I'm going to try some of both on different parts to test, thanks guys.
#6 |
It was likely a rubber-based adhesive transfer tape. Try any of the 3M tapes using the 300 series adhesive. Heres the 3M engineered adhesives site and the product guide for some of their tapes.
http://www.3m.com/us/mfg_industrial/...es/index.jhtml http://www.3m.com/us/mfg_industrial/...rodSummary.pdf AFAIK, there are 4 main classes of adhesive that I know of: acrylates, rubber-based, silicones and epoxies. While silicones will also stick rubber and plastic, they are far too expensive for cell phones. Just about every item that has a flat surface that has to be stuck to another flat thing uses some kind of double-sided transfer tape. It is the fastest, and thus, cheapest way to bond two thing together permanently. Check out the VHB line of 3M tapes. In general, if a tape isn't strong enough, you need epoxies or other "activated" adhesives. :)ensen.
Those who claim to be making history are often the same ones repeating it. |
| bonding gator board? | NED 209 | Everything Else | 1 | 3rd April 2008 12:04 PM |
| Bonding silver foil to PTFE | Nixie | Everything Else | 29 | 20th January 2007 09:54 PM |
| Thermally bonding TO-92 transistors | fluckscapacitor | Solid State | 8 | 17th December 2006 06:14 PM |
| SME 3009 rubber | turntableKid | Analogue Source | 2 | 14th October 2004 04:02 AM |
| Page generated in 0.11016 seconds (62.09% PHP - 37.91% MySQL) with 10 queries |
