Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 30th July 2011, 12:56 PM   #11
DF96 is offline DF96  England
Originally Posted by Speedskater
But more correctly it's also the leakage resistance of the insulator (conductance) that makes the formula very messy at audio frequencies.
Yes, but in practice I think it turns out that at audio frequencies insulator conductance is negligible when compared to capacitive reactance, but conductor resistance dominates inductance.
Old 30th July 2011, 01:38 PM   #12
Speedskater's Avatar
Jim Brown has a good paper on Transmission Lines at Audio Frequencies:
http://www.audiosystemsgroup.com/TransLines-LowFreq.pdf
Dynaudio Ocos Loudspeaker Cable has very high insulator conductance:
http://www.dynaudio.com/eng/pdf/DYN_...Grundl_INT.pdf
A solution in search of a problem.
Kevin
Old 30th July 2011, 05:03 PM   #13
Elvee is offline Elvee  Belgium
That's debatable: a typical figure-of-eight speaker cable has a lineic resistance of ~15milliohm/m, and a lineic inductance of ~1µH/m.
At a frequency of 10KHz, this is equivalent to 62milliohm/m, 4 times the resistive part.
Old 30th July 2011, 06:23 PM   #14
At 1kHz, assuming your figures, it would be 0.4 times the resistive part so in the LF-mid region where audio signals are strongest the resistance dominates. OK, I will qualify my statement: for most of the audio band resistance dominates. If you consider the audio band to have ten octaves, then only the top three(ish) have inductance dominating. My main point was that you have to consider inductance, resistance and capacitance but you can usually ignore insulator conductance.
Old 30th July 2011, 08:06 PM   #15
I completely agree: all current polymers, including the humble PVC can be considered as perfect in this respect, and for this application.
Trafo bad, or am I bad caxxxxxx Chip Amps 24 3rd May 2011 08:56 AM
How much (capacitance) is too much? dobias Power Supplies 56 10th April 2011 08:29 AM
Too much capacitance? HaLo6 Power Supplies 24 14th June 2009 05:55 PM
from A(udiobahn) to Z(apco) amps, what makes it so good or bad? profuse007 Car Audio 2 14th February 2006 01:46 PM
How much capacitance? theAnonymous1 Solid State 4 22nd June 2004 08:01 AM
Page generated in 0.09281 seconds (68.71% PHP - 31.29% MySQL) with 10 queries
