Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
What makes capacitance bad??
Old 29th July 2011, 06:43 PM   #1
jdsackett is offline jdsackett  United States
Default What makes capacitance bad??
Hi guys. I'm taking some online lessons in circuits and have a question about interconnects and speaker cables. In my current lesson, it says that capacitors pass voltage when it changes and acts like a short with dc. So, if it will pass changing voltage, which music is, changes all the time, why is capacitance bad in a cable?? Seems like it wouldn't matter, as the message(music) would get through just fine?? On the other hand, I want to make some interconnects and all the sites i have been to mention capacitance as an evil that must be avoided. How come?? Don't flame me too badly guys, I'm only trying to learn something. Thanks and regards, J.D.
Old 29th July 2011, 07:06 PM   #2
Mooly's Avatar
Interconnects... two cables running together (the inner core and outer shield) form a capacitor. In effect they are two plates side by side. Longer lead length = larger value of capacitance. So far so good
The output of a source component is not zero ohms but some other (usually low but not always) value. So if the output impedance was highish then the capacitance of the lead would form a simple R/C filter and roll off or attenuate the high frequencies. In practice it's not such a problem with normal length interconnects.
Speaker leads... same applies in theory... in practice the output impedance of an amplifier is always low so the attenuation thing isn't an issue.
Also small levels of capacitance can cause instability if say an interconnect were connected directly to the output of a high speed opamp.
Old 29th July 2011, 07:30 PM   #3
AdamThorne is offline AdamThorne  United States
AdamThorne's Avatar
The two conductors bound together act like the two plates of a capacitor, so that's where the capacitance comes from. But it's not capacitance from one end of the conductor to the other (which would pass AC, like you're talking about*), it's from one conductor to another. So at (very) high frequency the capacitive cable acts like a short. Well, that's the extreme case, more likely it just throws something else off.
* Your cables would make a very small capacitance, most likely, and wouldn't be useful for passing music even if it was in this alignment.
My understanding, anyway.
Old 29th July 2011, 07:33 PM   #4
DF96 is offline DF96  England
A coupling capacitor (passes AC, blocks DC) is in series with the signal; together with the input resistance of the next stage it forms a high-pass CR filter so the capacitance value must be high enough to pass the lowest frequencies. Have a look at CR filters.
Cable capacitance is in parallel with the signal, so together with the output resistance of the previous stage it forms a low-pass CR filter so the capacitance value must be low enough to avoid reducing the highest frequencies.
You need to understand these basics before worrying about other effects which may or may not happen. Bear in mind that cables are a topic that people argue about.
Old 29th July 2011, 08:06 PM   #5
Thanks guys. Knew this was the place to ask. Thank you for keeping it simple. I understood what you fellas were saying!!!!! Must be learning something. Much appreciated guys. Best regards, J.D.
Old 29th July 2011, 08:38 PM   #6
Elvee is offline Elvee  Belgium
Elvee's Avatar
One more thing, and I hope it will not confuse the issue too much: capacitance in a cable is not the same as pure capacitance in a component f.e.: it is partially or completely balanced by the inductance of a cable.
This means that you can carry broadcast quality signals on hundreds of feets of cable.
There are second order effects that limit the bandwidth, but anyway, capacitance is not the primary limiting factor: in a speaker cable, inductance is the dominant one, because the charateristic impedance of the cable (something like 80 ohm, for ordinary cable) is much higher than the impedance of your speakers.
Old 29th July 2011, 08:43 PM   #7
Thank you all. Well spoken fellas in language i could understand!!! Never occurred to me that it was in parallel instead of series. Duh. Well, like i said, i'm learning. Thanks again fellas, really appreciate it. Best regards, J.D.
Old 29th July 2011, 09:00 PM   #8
True for RF, less true for audio. In most audio cables the inductance is swamped by resistance, so the characteristic impedance becomes complex and frequency dependent.
(OP please ignore this post if it confuses you - Elvee and I are talking about more complicated effects than simple CR filters).
Old 30th July 2011, 12:03 AM   #9
Speedskater is offline Speedskater  United States
Speedskater's Avatar
It confuses most people!
But more correctly it's also the leakage resistance of the insulator (conductance) that makes the formula very messy at audio frequencies. Once we get to radio frequencies we can use the simpler formula.
Kevin
Old 30th July 2011, 01:36 AM   #10
indianajo is offline indianajo  United States
indianajo's Avatar
Another way they describe the parallel capacitance of a cable (say an RCA jack cable) is "parasitic" capacitance, that is it takes current to drive it, that doesn't get to the end and do anything useful. Current costs money. Right now, LM4560 op amps that will drive a lot of current very fast, are over $2, whereas 4558's that won't put out much current fast at all, are about $.25. The power supply that will drive a 24 channel mixer board with LM4560's is a lot more expensive than the power supply that only has to support 24 channels of 4558 op amps. That 100' snake cable from mixer to power amp, has a whole lot of parasitic capacitance. Before "electret" mikes with a little internal amp, you couldn't put the mikes 100' from the mixer, because the mikes wouldn't drive the capacitance of the cable without a mike amp up there on stage. "Dynamic" mikes that would drive a lot of cable, didn't pass many high frequencies so they weren't much use for symphonies, only voice and pop bands. High frequencies from a medium source impedance like a dynamic mike, get lost in the capacitance of the cable.
Another example- a popular phono preamp from 1961 was the tube PAS2. It only put out enough current to drive the parasitic capacitance of a 6' RCA cable, plus the input of the power amp. There were other preamps that would drive a lot more cable, but they didn't sell as well because they cost a lot more, using more capable, lower volume tubes and a bigger power supply. As well, the preamp had to be less than 6' from the magnetic phono cartridge on the turntable, because the un-amped cartridge can't drive the parasitic capacitance of more RCA cable.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
What makes capacitance bad??Hide this!Advertise here!
Trafo bad, or am I bad caxxxxxx Chip Amps 24 3rd May 2011 09:56 AM
How much (capacitance) is too much? dobias Power Supplies 56 10th April 2011 09:29 AM
Too much capacitance? HaLo6 Power Supplies 24 14th June 2009 06:55 PM
from A(udiobahn) to Z(apco) amps, what makes it so good or bad? profuse007 Car Audio 2 14th February 2006 02:46 PM
How much capacitance? theAnonymous1 Solid State 4 22nd June 2004 09:01 AM
Copyright ©1999-2017 diyAudio
