diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   Wireless router D-Link DIR-635 making high pitched noise (http://www.diyaudio.com/forums/everything-else/192101-wireless-router-link-dir-635-pitched-noise.html)
Rodeodave 5th July 2011 09:36 PM
My D-Link DIR-635 emits a high pitched tone from it's circuit board which is very, very annoying. It makes the noise regardless of what power supply is being used with it and it's definitely coming from the circuit board.
The circuit is running from 5V. If I connect the router to a regulated PSU the noise is there as well, and if I feed it with less than five volts the pitch changes. The pitch also changes with blinking of the status LED, so I suspect it's an onboard-PSU issue.
I have already varnished all coils that are on the board with superglue, but it didn't change a thing. I desoldered some of the capacitors to see if the noise came from them, but it didn't help or give any new clues. For me it's impossible to locate the origin of the noise on the board just by listening, I think the pcb conducts the sound too well for that.
Does anybody have any ideas how to tackle the problem? Any known suspects on the board to look out for? What other pats can make a noise that high (downmodulation maybe)?
Edit: There are two of those cheapish crystal oscillators on the board, one 12.000 and one 25.000 (I'm guessing that's MHz?). Could they have gone "bad" and cause disturbance in the audible frequency range?
simon7000 5th July 2011 10:46 PM
Since it changes with input voltage it is very likely a switching regulator that takes the input power and makes what is really needed. Take it out of the case and press things with you finger as there are no high voltages until you figure out which part makes the noise. My guess would be a small transformer coil, but it could be a capacitor.
Rodeodave 5th July 2011 11:07 PM
Thanks for your input! I have already taken it out the case and poked around with my finger, but nothing notable happens. I will probably remove the caps on by one (there are maybe seven or so) and see if it makes a difference. There are four inductors on the board, and I already soaked them with superglue, so nothing should be moving there.
I hope I find the source, it's really annoying...
kouiky 8th December 2014 01:13 AM
A few years back I bought a D-Link power over ethernet kit for use outaide the range of my wireless network. The sender module doesn't make any audible noise, but the receiver does. My modem makes an annoying high pitched sound after it has been on for some times, but this D-Link PoE receiver makes a much higher tone. When I disconnect a device, I have no choice but to remove power from it, because it does a search every 8 seconds or so, producing an audible pitch that can be heard outside the room and lasts for several seconds.
I've come to avoid devices with switch mode power supplies, because many generate these tones that some people can't hear. Another of the other offenders includes USB power outlet wall warts. It would be nice to find what can be done about the noise, firstly by identifying the exact cause.
kouiky 7th March 2015 02:23 AM
Rodeodave, how well did this damping method work in the end?
wwenze 7th March 2015 05:20 AM
Ahh... D-Link... That DHP-308AV powerline...
Bought one, whine
Went to service centre for an exchange, whine even loader
Now sitting collecting dust. Went TP-Link instead, both units very quiet.
Rodeodave 7th March 2015 06:19 AM
No noticeable effect at all. I never figured out what was singing on that particular circuit board, wasn't the crystal oscillators either. I moved to fiber internet and got provided with a modem/router with integrated wifi.
Resources saved on this page: MySQL 18.75%
