| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
| View Poll Results: Use both measurements and listening? | |||
| Yes |
20 | 95.24% |
| No |
1 | 4.76% |
| Voters: 21. You may not vote on this poll | |||
#11 |
If you did not have some form of metrics how could reproduce you results.
#12 | |
just another
sy's post suddenly made sense and was funny really need more sleep!10 yes and 0 no. good sign Tony. |
#13 | |
49 - for the 17th time
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() :head bash:![]() ![]() ![]() ![]()
DIY audio can be expensive – but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
#14 |
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing."
-Daniel R. von Recklinghausen former Chief Research Engineer H.H. Scott Peace, Dave Gerecke |
#15 |
nothing to loose by voting yes
and I can't imagine anyone voting no ![]() ![]() even if I use listening only, I cannot recommend it ![]() anyway, most of my knowledge and experience is based on other peoples measurements would have been totally impossible without |
#16 |
Hi, it is such a stupid question, answering it gives credibility it does not deserve, rgds, sreten.
A better question might be can it be done using ears only, not should it be. Not easily IMO.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#17 | |
I mean, it would have very little 'reason' but you might better ask, 'using measurements only that might be a little less predetermined but again, I think it would be strange to design a speaker without listening to it
#18 |
I vote no!
With all the good simulation software available these day (spice, and others) why would anyone need to measure or listen? Just sim it and you're ready to go! What could be easier? This is the 21st century, isn't it? Let's get on with it.
Take the Speaker Voltage Test! |
#19 |
Ok, we answered the question. What's next? Should we use cows to test audio equipment, huh?
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#20 |
just another
Playing the devils advocate are we pano?
either that or someone has hacked your account!! Tony. |
| First Time Builder, Building a Cheap Speaker | SnoopKatt | Multi-Way | 44 | 7th May 2010 09:43 AM |
| Power Measurements at normal listening levels | TheGimp | Tubes / Valves | 21 | 12th October 2009 05:31 PM |
| X-over designer wanted ... | Madmike2 | Swap Meet | 10 | 11th July 2005 02:46 AM |
| Enough building, more listening | phishead8 | Everything Else | 2 | 30th April 2002 01:26 AM |
| Hello, from amp designer | rmetz | Introductions | 2 | 29th January 2002 07:18 PM |
