| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I would like to make a small ultra sound cleaner with piezo tweeters. Can those piezo tweeters produce the frequency of 40KHz?
#2 |
I also have a couple of 43KHz piezo tweeters. How are you going to power them and generate the signal?
#3 |
This is something I've wondered about too. One of my other hobbies is model railways, and cleaning up an etched brass loco kit is a bit of a pain. An ultrasonic cleaner would be a very useful tool, and though the small ones are pretty cheap, the price seems to rise exponentially as you get to a useful size.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 | |
If you have a good sound card You can generate the 44KHz using software like Cool Edit. BTW, i still dont know what is the desired shape of the signal of 44KHz for sono cleaners, if it should be sine, or square? Last edited by GoranB; 29th May 2011 at 02:47 AM. |
#5 | |
I want to build an water container: 320mm x 50mm x 120mm to clean LP's. |
#6 | |
Thanks |
#7 | |
I have never tried something like that. But i think the placement of the transducers on a particular container is essencial, so i dont think that increasing the container will be effective. But maybe im wrong. At work i have several ultrasound cleaners, different sizes and its very difficult to remove the transducers, in some cases they are sticked on the bottom of the container with some special glue . |
#8 |
I just find out the characteristics for piezo's i have.
Frequency 4,2KHz Impedance 300 OHM's Capacitance 24nF From my experience they can produce much higher frequency. To get 8 OHM's i should connect 40 piezo's in parallel to the output of TDA2030. |
#9 |
The impedance at ultrasonic frequencies is not going to be 300 ohms! Working off resonance, the efficiency will be low. You need ultrasonic piezos to do this correctly.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#10 |
| some experience with Ultra sound cleaner? | GoranB | Everything Else | 0 | 28th May 2011 08:57 PM |
| Do piezo tweeters sound worse? | Racket Scientist | Multi-Way | 4 | 2nd November 2010 10:14 AM |
| How well do piezo tweeters do | skooter | Car Audio | 2 | 2nd September 2008 09:05 PM |
| Piezo Tweeters | subwo1 | Everything Else | 6 | 22nd August 2002 11:46 PM |
| Using piezo tweeters | Rory | Multi-Way | 15 | 6th November 2001 08:46 PM |
| Page generated in 0.12497 seconds (70.75% PHP - 29.25% MySQL) with 11 queries |
