Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Im being thick Variable Resistor to Rheostat
Old 11th May 2011, 09:06 PM   #21
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Measure the same wire i did for the volage feeding the controller?
yes
Where is the connection to power the PWM board? How are you powering the PWM circuit?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 11th May 2011, 09:17 PM   #22
Pjalchemist is offline Pjalchemist  United Kingdom
Originally Posted by sofaspud View Post
yes
Specs for the unit are
1. Input 12VDC - 40VDC, output to motor is 12VDC - 40VDC corresponding.
2. Maximum current 10A.
3. Output frequency 25Khz.
4. Duty cycle adjustment range: 0%-100
I have 12V off the ATX PC PSU via a Molex and cable rated 12v 10A
2) Control knob all the way to the minimum 12.02v
(3) Control knob all the way to maximum 11.38v
When turning to max it dips to 11.26v these rises to the above
A100K Verable Resistor - It came with the kit is the speed control
Old 11th May 2011, 09:35 PM   #23
sofaspud's Avatar
You can see that it drops below the spec'd 12v minimum input.
I can't be 100% sure that is the cause of the problem. It's not good in any case.
I don't know what else to tell you.
Old 11th May 2011, 09:40 PM   #24
Just a thought. I think the problem is it's PWM and really needs to be linear, so maybe a PWM to linear is needed
Old 11th May 2011, 09:56 PM   #25
sofaspud's Avatar
The way I see it, it makes little sense here to generate significant heat to implement a working cooling project. Keep the fans and linear circuit separate by some distance.
Old 12th May 2011, 12:07 AM   #26
wakibaki is offline wakibaki  United Kingdom
Banned
Runs @ 7V but not @ 7V PWM equivalent?
Try a BIG capacitor across the output. 10,000 uF, 16V working.
It's pretty fast switching, so if you can find a choke from a SMPS (this'll be a toroid wound with THICK wire) try that in series too. Not the common mode one (bifilar wound, a pair of wires), although you can just use one winding, or rewind it.
There's no guarantee this will fix it, so any large cap, or smaller ones in parallel, with >12V working you can scrounge from something broken.
w
Old 16th May 2011, 03:14 PM   #27
w
Sorry thats flown over my head a bit
Im being thick Variable Resistor to RheostatHide this!Advertise here!
variable resistor? studiostevus Digital Line Level 0 11th December 2010 09:28 AM
variable resistor akis Solid State 23 15th May 2010 07:44 PM
Do I need a resistor if Im going directly from rca... bundee1 Class D 1 6th April 2010 02:05 AM
Ohmite 32 ohm 300W rheostat power resistor boywonder Swap Meet 0 31st May 2009 02:37 AM
Using a variable resistor in the feedback loop. darren01 Chip Amps 9 30th December 2003 11:05 AM
Copyright ©1999-2017 diyAudio
