Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Any opinions on this article about cable resonances ?
Old 1st May 2011, 03:04 AM   #1
tessier is offline tessier  Canada
Default Any opinions on this article about cable resonances ?
Hi
Are cable resonances real and can they be audible? : Empirical Audio
Thanx
Paul
Old 1st May 2011, 03:20 AM   #2
stratus46 is offline stratus46  United States
Originally Posted by tessier View Post
Hi
Thanx
Paul
I won't say it can't be heard but those resonances are up around 10 MHz. The amplifier output they show is NOT an audio amp. It's a better than average std def video amp. To reduce the effects an inline 'terminator', actually more along the idea of a grid stopper would damp out all the resonance as it would form a single pole low-pass filter with the cable capacitance as one of the components.
You NEVER drive a cable directly from the output of an opamp as the capacitance changes the stability. Check any operational amplifier data sheet for capacitive loading issues.
Even when I was younger 10 MHz was a stretch.
G
Old 1st May 2011, 03:24 AM   #3
Conrad Hoffman is offline Conrad Hoffman  United States
Never give too much credence to people trying to sell you something.
I may be barking up the wrong tree, but at least I'm barking!
Old 1st May 2011, 04:12 AM   #4
infinia is offline infinia  United States
infinia's Avatar
before you can sell a so called solution you must invent the problem 1st.
1) real audio amplifiers have a limited bandwidth and not able to support the rise / fall times to excite so called zip cord resonances.
2) most amplifiers feature damped series inductors to decouple their outputs from seeing the bad zip cord resonances which are shown well beyond the bandwidth of any audio signal, that they say is a the problem.
these are not a real world examples or problems
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 1st May 2011, 04:35 AM   #5
eclectic2k is offline eclectic2k  United States
eclectic2k's Avatar
I agree with infinia. Interesting that at first glance, everything he covers seems to be true and correct, just completely meaningless.
For all the science he uses in the body of the article, he links it to real world audio with only one or two sentences of very vague reasoning or basis...
in the end, it's just more FUD.
If anyone really needed such cables, they should first look at why the amplifier is so poorly designed...
Old 1st May 2011, 08:51 AM   #6
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Ah, yet another peddler of expensive wire deliberatly misapplying basic engineering / physics in an attempt to blind the gullible. I don't think many of us need to stay awake nights worrying that our speaker wire is resonating a couple of decades or more above the HF limit of human hearing.
A rather better page on the subject: Debunking the Myth of Speaker Cable Resonance — Reviews and News from Audioholics
Old 1st May 2011, 04:52 PM   #7
DF96 is offline DF96  England
Are cable resonances real? Yes, just like any misterminated transmission line.
Can they be audible? No, unless your loudspeakers and ears extend up to MHz frequencies.
One small note: if a cable resonance happens to coincide with an interfering RF source then the effect of RF interference may be made worse. In this sense, and this sense alone, they may become audible. The solution is to improve the RF rejection of the equipment by adding filters on each port. Simple LC or RC low pass filter, adds a few pence to the cost.
Any opinions on this article about cable resonances ?Hide this!Advertise here!
Q of audible resonances. Dr_EM Multi-Way 14 28th July 2010 01:22 AM
Cabinet Resonances gazzagazza Full Range 30 18th April 2010 01:19 AM
Measuring resonances pixpop Analogue Source 14 4th October 2006 02:43 PM
Room resonances Positron Tubes / Valves 28 12th December 2003 03:27 AM
Copyright ©1999-2017 diyAudio
