Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 20th April 2011, 12:18 PM   #1
Gunders is offline Gunders  Norway
Default Problems understanding I/V converter from DAC
Hi
I'm trying to understand the I/V converter used in this schematic. I have a problem seeing why they have connected the non-inverting input to the inverting output from the DAC instead of grounding it. Do they achieve anything by doing this? I also wonder why they use an I/V converter when it is a voltage output DAC.
Datasheet for the MAX5184 DAC: http://datasheets.maxim-ic.com/en/ds...81-MAX5184.pdf
Thank you for your help in advance
Old 20th April 2011, 12:32 PM   #2
zigzagflux's Avatar
What makes you think this is an I/V converter? Looks to me like a poor implementation of a differential amp.
Old 25th April 2011, 10:15 PM   #3
DF96 is online now DF96  England
Are they using the opamp as a unity gain buffer, with some frequency compensation to keep it stable? Just a guess, as I am not familiar with either chip.
Old 25th April 2011, 11:10 PM   #4
cbdb is offline cbdb  Canada
Its an I/V converter. No current into the opamp inputs so Vout =Iin- x (R19//C129) , or Iin- x 3.3k till the caps impedance reaches 3.3k then Vout drops,(low pass filter). Someone else can do the math.
Old 26th April 2011, 12:04 AM   #5
Originally Posted by Gunders View Post
Hi
The spec sheet says the MAX5184 has 400 ohm internal load resistors on the current outputs, so the chip's outputs are already "voltage". The opamp is simply a buffer with some gain.
Bobby Dipole
Old 26th April 2011, 12:12 AM   #6
The one and only
Nelson Pass's Avatar
Looks like a regular I/V converter. Maybe they tie the plus input of the op amp to their internal ground to insure accuracy.
USB-S/PDIF converter and DAC paulb Digital Line Level 22 14th June 2010 05:57 PM
Arcam Alpha 8 as a DAC converter shortbloke Digital Source 0 18th September 2008 02:01 PM
How far can IV converter be from DAC? philpoole Digital Source 7 30th April 2007 03:05 PM
EMC problems with flyback converter DaBit Power Supplies 6 17th September 2005 07:50 AM
Soundstream DAC-1 D/A Converter??? Yoda Digital Source 1 8th February 2002 05:06 AM
Page generated in 0.15290 seconds (47.21% PHP - 52.79% MySQL) with 11 queries
